Calculus Tangent Line: Find Parameter k | Camille's Q&A
In summary, the value of k for which the line 3x-4y=0 is tangent in the first quadrant to the curve y=x^3+k is (b) 1/4.
MarkFL
MHB
13,288
Here is the question:
Calculus tangent line?
If the line 3x-4y=0 is tangent in the first quadrant to the curve y=x^3+k then k is
(a)1/2
(b)1/4
(c)0
(d)-1/8
(e)-1/2
Could you please show work because I am so lost
I have posted a link there to this topic so the OP may see my work.
Mathematics news on Phys.org
Hello Camille,
Let's begin by equating the derivative of the curve to the slope of the tangent line. The tangent line may be written as \(\displaystyle y=\frac{3}{4}x\) hence:
\(\displaystyle \frac{3}{4}=3x^2\)
\(\displaystyle x^2=\frac{1}{4}\)
Since we are interesting in the first quadrant solution, we take the positive root:
\(\displaystyle x=\frac{1}{2}\)
Now, the tangent line and the curve have then tangent point in common, and so using the tangle line, we know this point is:
\(\displaystyle \left(\frac{1}{2},\frac{3}{4}\cdot\frac{1}{2} \right)=\left(\frac{1}{2},\frac{3}{8} \right)\)
Hence, we must have:
\(\displaystyle y\left(\frac{1}{2} \right)=\left(\frac{1}{2} \right)^3+k=\frac{1}{8}+k=\frac{3}{8}\)
And so we must have:
\(\displaystyle k=\frac{1}{4}\)
Here is a plot of the curve \(\displaystyle y=x^3+\frac{1}{4}\) and the tangent line \(\displaystyle y=\frac{3}{4}x\) for $0\le x\le1$:
FAQ: Calculus Tangent Line: Find Parameter k | Camille's Q&A
What is a tangent line in calculus?
A tangent line in calculus is a line that touches a curve at a specific point and has the same slope as the curve at that point. It represents the instantaneous rate of change of the curve at that point.
How do you find the equation of a tangent line using calculus?
To find the equation of a tangent line using calculus, you first need to find the derivative of the function at the point of interest. Then, you can use the point-slope form of a line to plug in the coordinates of the point and the derivative value to find the equation of the tangent line.
What is the parameter k in calculus?
In calculus, a parameter k is a constant value that is used to represent a specific point or value in a function. It can also be used to represent a specific slope or rate of change at a given point on a curve.
How do you find the value of the parameter k in a tangent line equation?
To find the value of the parameter k in a tangent line equation, you can use the point-slope form of a line and plug in the coordinates of the point and the derivative value at that point. This will give you a simplified equation with the parameter k as the slope, which you can then solve for.
Why is finding the equation of a tangent line important in calculus?
Finding the equation of a tangent line is important in calculus because it allows us to approximate the behavior of a curve at a specific point. This can help us understand the behavior of functions, make predictions, and solve real-world problems that involve rates of change.
