Electrical Calibrating a metal leaf or pith ball electroscope
The discussion focuses on building a DIY metal leaf or pith ball electroscope with a circular arc voltage scale for measuring deflection. The user seeks to calibrate the scale by determining charge density, weight, thickness, and area of the leaves or pith balls, applying equations of deflection to achieve ballpark accuracy. They aim to measure the voltage applied to the electroscope using a high-voltage electrostatic generator without purchasing an expensive device. The user acknowledges the challenges of relating capacitance to their setup, as one plate is the leaves and the other is Earth ground, complicating the application of standard capacitor equations. They also clarify that the output from their generator will be AC, which is not purely electrostatic, and consider alternative methods for generating electrostatic charge.
TJonline
TL;DR Summary
Trying to calculate the charge density upon the leaves as a function of voltage applied to a DIY metal leaf or pith ball electroscope without knowing the voltage applied (relative to earth ground) beforehand.
I'm trying to build a DIY metal leaf or pith ball electroscope. I want to provide it with a circular arc voltage scale visible directly behind the (deflected) ends of the leaves. To calibrate the scale with ballpark accuracy, I want to determine the charge density upon the leaf pair (or pith balls), measure their weight, thickness and area (or volume) and apply the equations of deflection (of the pith balls):
https://www.physicsforums.com/threads/force-components-of-hanging-pith-balls.779971/
Or a hairier integral as to two leaves deflecting at varying angles. Ultimately, I want to determine the voltage applied to it (relative to Earth ground) provided by a cheap, high-voltage, step-up, transformer-terminated (and earth-grounded output terminal), electrostatic generator module (or Van der Graff generator) without buying an expensive electroscope and measuring the voltage that way to calibrate the circular arc scale. I'm aware of the equation: C = Q / V = e A / d = e0 er h w / d, where e0, er, h, w and d are permeability of free space, relative permeability, plate height, width and distance between plates. But in this case, one plate is the two leaves (or pith balls) with identical (repulsive) charge and the matching plate is Earth ground an 'infinite' distance away. Capacitance C goes to zero as d goes to infinity, and thus so does charge C, according to the capacitor equation. It's not really a capacitor per se. But the leaves have a charge obviously. Can't seem to find the physics/engineering information that I need to determine the charge and voltage (both being unknowns). The capacitor equation always comes up when I search on 'plates', 'charge', 'voltage', 'electroscope', etc. Any ideas? Or is that too vague?
Oops! Me so stupid. If those modules are terminated by a transformer, then all that can come out is pure AC. Which is not electrostatic. So, make that either a Van der Graff generator or some silk cloth rubbed on a glass rod.
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
