MariosB
- 4
Hello everyone,
As a part of my computational physics course i have been assigned a homework which is pretty simple. My problem is in optimising my source code. So the task is this:
Write programs that calculate the machine round-off error for a real type variable with precision levels : kind=4, kind=8, kind=10. If we think this in terms of making different source codes or even a main program that will call three separate subroutines each one setting our desired amount of precision it would be easy and the code is something along the lines of this
As i said, i want to optimise my program, in this sense :
I want to have only one kind of subroutine that will be calculating each time the round-off error but i want to be able to change the kind of the real type variables accordingly depending of the level of precision i want. For this reason i have tried to write something like this :
The idea is to incert a module which will set the kind in an integer-parameter and it will be used later on depending on the selection of the user. Since it is the first time i have ever needed to write something like that could you please tell me if the syntax i am using is even possible ? My idea is that each time the subroutine precison_calc(choice) will be called a different type of use command will be activated depending on the original choice of the user. But can i use the "use" statement in such a way either inside or outside the subroutine?
Also, does any1 know how can i see Fortran 77 / 90/95 intrinsic functions source codes? I have a hunch that be studying the structure of the mathematical intrinsic functions I can probably find a solution to my problem.
My interest is mainly academic in nature.
Thanks in advance !
Code:
PROGRAM Machine Epsilon
implicit none
integer :: exit,choice,counter
common /counts/counter ! if i declared this inside the subprogram each time it would run anew it
! would not reset the counter value. Outside seems to work just fine.
Print*,
Print*,' This program calculates the machine Round-off error,epsilon, for single, '
Print*,' double and high precision. Please specify the desired level of precision.'
Write(*,*)
5 Print*,' For single precision press 1 '
Print*,' For double precision press 2 '
Print*,' For high precision press 3 '
Print*,
Print*,' To exit press 5'
Read*, choice
do while ((choice.ne.1).and.(choice.ne.2).and.(choice.ne.3).and.(choice.ne.5))
Print*,' Invalid choice '
Print*,' Please select the amount of precision you prefer '
Print*,' for the calculation '
Read(*,*) choice
end do
select case (choice)
case(1)
counter=0
call precision_4
case(2)
counter=0
call precision_8
case(3)
counter=0
call precision_10
case(5)
go to 60
end select
48 Print*,'Press 5 to exit or 4 to start again'
Read(*,*) exit
if ( exit .EQ. 5 ) then
go to 60
elseif ( exit .EQ. 4) then
go to 5
else
go to 48
end if
60 end program machine epsilon
c Single Precision Subroutine
c=======================================================================================================
subroutine precision_4
real(kind=4) :: temp,epsilon
integer :: counter
temp=1.5 ! the value of variable temp has been selected at random, with the sole limitation
! it being reasonably higher to the machine roundoff error for the following calculation
! to have meaning.
do while ( temp+1.0 .gt. 1.0 )
temp=temp/2.
epsilon=temp
counter=counter+1
end do
Print*,' Machine round-off error is, e = ',epsilon
Print*,' Calculated after ',counter,' repetitions'
return
end subroutine precision_4
c Double Precision subroutine
subroutine precision_8
real(kind=8) :: temp,epsilon
integer counter
temp=0.5
temp=temp/2.
epsilon=temp
counter=counter+1
end do
return
end subroutine precision_8
c High Precision Subroutine
subroutine precision_10
real(kind=10) :: temp,epsilon
integer :: counter
! to have meaning.
temp=temp/2.
epsilon=temp
counter=counter+1
end do
return
end subroutine precision_10
Code:
module PrecisionLevel
integer, parameter :: kd4=4,kd8=8,kd10=10
external epsilon
end module PrecisionLevel
PROGRAM Machine roundoff error
implicit none
integer :: ext,choice
Print*,
Write(*,*)
Print*,
Read*, choice
Read(*,*) choice
end do
case(1)
call precision_calc(choice)
case(2)
case(3)
case(5)
go to 60
end select
Read(*,*) ext
if ( ext .EQ. 5 ) then
goto 60
else if ( ext .EQ. 4) then
goto 5
else
goto 48
end if
60 end program machine roundoff error
! Single Precision Subroutine
subroutine precision_calc(choice)
integer :: counter,choice
case(1)
use PrecisionLevel, only: kd4=>kd
case(2)
use PrecisionLevel, only: kd8=>kd
case(3)
use PrecisionLevel, only:kd10=>kd
end select
real(kind=kd) :: temp,U
temp=0.5
counter=0
do while ( temp+1._kd .gt. 1._kd )
temp=temp/2._kd
U=temp
counter=counter+1
end do
Print*,' Machine round-off error is, e = ',U
return
end subroutine precision_calc
Thanks in advance !
