Calling functions without recalling all variables
In summary, the conversation discusses the function f2 and whether it needs to explicitly include the variables var1 and var2 or if it can be written without them. The idea of using a class to hide the variables is also brought up, as well as the use of global variables and the potential for side effects. Ultimately, the concept of information hiding in object-oriented programming is suggested as a solution for this issue.
member 428835
Hi PF
Given the following
Python:
def f1(var1, var2):
    var3 = var1 + var2
    return var3
def f2(var1, var2, var4)
    var4 = 10
    var5 = f1(var1, var2)*var4
    return var5
it is obvious function f2 does not explicitly need variables var1 and var2. However, it needs the result of f1, which relies on var1 and var2. Is there a way to write the f2 function without having to pass into it var1 and var2? Could this be handled better with classes?
Technology news on Phys.org
Well, 'var4' doesn't seem to be doing anything useful.
typo, my bad. but you get the idea
<shrug> something like...
Code:
/* not python'y but you get the idea */
def f1(a,b)
return a+b.
def f2(c,d)
return c*d.
w = f2(f1(x,y),z)
If your objection is that f2 does not need to know the values of var1 and var2, then you are correct that you could use a class to hide those values away from f2. This is called "information hiding". It is a key idea of Object Oriented Programming. Of course, even with a class, those variables must be set somewhere before f2 calls f1. The concept makes the most sense in examples where the hidden information belongs to an object that "owns" the information and is the only thing that really needs to know or manipulate that information.
Likes member 428835 and Wrichik Basu
Here's a simplified version of the code from post #1, with extraneous variables and parameters removed:
Python:
def f1(var1, var2):
    return var1 + var2
def f2(var1, var2):
    return 10 * f1(var1, var2)
Since f2 is essentially a composite function (using math terminology), and f1 takes two parameters, then f2 also needs to take two parameters.
Note that it's possible to return an expression directly without have to first store the value of that expression in a variable.
  • Love
Likes Vanadium 50
Doesn't it? It gets set to 10 every time f2 is called. Presumably, that's the intent.
Ah, so Python uses global variables... then why bother passing parameters ?
var4 isn't a global variable; it's a local variable in function f2.
For the same reason we use functions with parameters in other languages that have global variables (which is pretty much all of them): because there are a lot of good reasons not to use global variables for everything.
If it's going to be 10 every time, var4 could be eliminated and "10" could be put in the line where var4 appears as a factor.
f2 sets it to 10. But f3 could set it to some other value.
If you want to say relying on side effects is bad coding, I agree with you. But side effects are still real.
f3 can't set it to anything. It's a local variable inside f2. f3 could pass a value for it other than 10 to f2, but that wouldn't matter, f2 would still overwrite it to 10.
Likes pbuk
I think you are missing the point that there is no side effect because var4 = 10 in f2 creates a new local variable var4.
Python scalars are not passed by reference.
Isn't Python pass by reference?
Not the way you mean. At the C level, yes, every Python object is ultimately a pointer; but the way the pointers are handled for function parameters make the behavior the same as pass by value in other languages. In Python there is no such thing as pass by reference as it exists in other languages; the only way to get that kind of functionality in Python is to pass a mutable object as a parameter and have the function mutate it (for example, setting items in a container or setting attributes on an object).
No function parameter in Python is passed by reference as that functionality exists in other languages. See my response to @Vanadium 50 just now.
It doesn't create the local variable because that local variable already exists as a function parameter. But it does force the object bound to that local variable to be a Python int object with the value 10, regardless of what object was bound to that parameter when the function was called.
I appreciate the distinction between "creates a new local variable" and "creates a new integer object and binds it to the symbol with local scope created by the declaration in the parameter, overwriting the existing binding", but I am not sure it is completely relevant here so I opted for brevity.
Thanks so much! This helps a ton! Below is a good example of what I was trying to do (which I was able to do after reading your comment).
Python:
class maths:
    def __init__(self, var1, var2):
        self.var1 = var1
        self.var2 = var2
    def f1(self):
        var3 = self.var1 + self.var2
        return var3
    def f2(self, var4):
        var5 = var4 * self.f1()
        print(var5)
if __name__ == "__main__":
    obj1 = maths(5,7)
    obj1.f2(4)
Likes FactChecker
Python:
class maths:
        self.var1 = var1
        self.var2 = var2
    def f1(self):
        return var3
    def f2(self, var4):
        print(var5)
    obj1 = maths(5,7)
    obj1.f2(4)
Just don't get too carried away with it. I have seen very simple algorithms turned into obscure code because everything was hidden away. It takes some wisdom and experience to balance the benefits and the cost.
Likes member 428835
