Cam -follower displacement as a time function
In summary: I think...maybe someone else can confirm it for me?In summary, the conversation discusses a cam with an offset of 10mm and a follower that rests on it vertically. The displacement of the follower vertically with respect to time is described by the equation 10*sin(wt), where w=2*3.14*N*t/60. The equation can be derived mathematically using parametric equations for a circle and specifying the units of the variables correctly. However, there is some confusion about the shape of the cam and whether the amplitude of the follower's displacement is actually sinusoidal.
chandran
139
There is a cam with offset of 10mm. A follower rests on it vertically. When the cam rotates at rpm N. I want to describe the displacement of the follower vertically with respect to time.
I can be shown that the displacement is 10*sin(wt) where w=2*3.14*N*t/60. But i want to derive it mathematically. Any diagrams will also help.
Mathematics news on Phys.org
Okay, your cam is an offset circle and you are modeling it by taking its "average height" as displacement 0. That means the maximum displacement will be 10 and minimum -10. Parametric equations for a circle of radius R are x= R cos s, y= R sin s where s is the angle, in radians, around the circle. Since the "displacement can be measured in either x or y direction, you could use either 10 cos s or 10 sin s for your model. Apparently you have chosen 10 sin s. Since s is in radians, one complete rotation corresponds to 2 pi (2*3.14 approximately) radian. You want to write s= wt so that one complete rotation: s= 2 pi corresponds to t= 1/N minutes (N revolution per minute corresponds to 1/N minutes per revolution). That is, when s= 2pi, you want
s= 2pi= w(1/N) so w= 2pi N. That's NOT what you had because I to t to measured in minutes (when I said "t= 1/N minutes") and you are NOT! It's a really good idea to specify what units your variables are in when you state the problem! Because I know that t seconds corresponds to 1 minute, I can see that, if we measure t in seconds, as you are doing, we have w= 2 pi Nt/60.
Hello
I'm new here and this is my first post.
The following is the derivation of the equation for displacement you've got:
Amplitude = 10mm
for an oscillation we can say it follows a sinusodinal path:
Displacement = ASin(wt)
where w = Angular Frequency
t = Time
A = Amplitude
we calculate W as follows:
1. The cam rotates N times per minute, so rotates N/60 times per second.
2. This is already an angular frequency, but angular frequency must be in Radians/second so we multiply N by 2Pi to convert it to Radians, giving
w=2Pi(N)/60
So we substitute these values into the origional equation giving:
D = 10Sin[(2Pi(N)/60)t]
I've included a diagram showing the displacement of the cam and how this relates to amplitude:
http://mobyhost.no-ip.com/cam.jpg
This is the simplest way I can think of deriving this formula, I think its correct.
Yes but is the ampletue of that offset circle cam actually sinusoidal? I think not, just look at the displacement at various angles of rotation (taking the maxium displacement as zero degrees) :
0 degrees : R+10 (max)
180 degrees : R-10 (min)
So far so good, but in that case we must have a displacement of R at 90 degrees however this is not the case.
90 degrees : sqrt(r^2 - 10^2).
EDIT: Yarr... I'm confused... scratch that...
yes, it is sinusodinal in the vertical displacement with respect to time.
I've drawn a little diagram to illustrate this:
http://mobyhost.no-ip.com/sin.jpg
Hope it helps
Edit: Assuming you take zero displacement to be when the cam is at 90 degrees rotated. (which for this question is correct as your plotting the movement of the cam follower - see diagram)
Greg
Sorry I must be looking at it wrong because I can't see it. It still seems to me that the vertical displacement at 90 degrees will be sqrt(r^2 - 10^2). Can anyone see what I'm doing wrong. Maybe I'll have to draw a diagram to show how I'm interpreting the problem but I don't have time right now.
uart said:
Sorry I must be looking at it wrong because I can't see it. It still seems to me that the virtical displacement at 90 degrees will be sqrt(r^2 - 10^2). Can anyone see what I'm doing wrong. Maybe I'll have to draw a diagram to show how I'm interpreting the problem but I don't have time right now.
what you do is you are looking at the vertical displacement of something riding up and down on top of the cam.
If you take the displacement to be zero when it is rotated 90Deg then it will show a sinusodinal relationship about this point as it rotates.
Ok, here is a really rough sketch of how I'm picturing it (sorry I don't have any vector graphics package on this PC right now so it's a very rough freehand.)
Can you see what I mean? The top circle shows the cam at maxium vertical displacement (zero degrees) and the bottom circle shows the cam at the 90 degree point. I am assuming that the cam follower is a piont that rides directly vertically above the point of rotation.
EDIT: Everything I wrote below is wrong
Thinking about what you said though, I think that the amplitude of a follower for an eccentric circular cam is not 10, it is 10 - (r^2 - 10^2). But it is still sinusodinal.
For what I was talking about (with an amplitude of 10) would be a cam that looks like this ( I assume this is what is being referred to in the question):
http://mobyhost.no-ip.com/cam2.jpg - Sorry I drew the cams incorrectly in my other diagram.
If not, then specify what sort of cam it is ?
Because right now, I'm getting super confused
Uart - yea I see what you mean but this just changes the amplitude, not the sinusodinal motion
EDIT: Ok, thinking about that pear cam, I think that's wrong becasue that would give a truncated sine wave of just bumps.
Ok now I see how you can get a sinusoid out of the offset circle cam. The follower has to be a line (horizontal line) rather than a point, that works ok.
your right, that is crazy. I'm totally confused now.
I'm no cam expert, only a lowly physics student. Any of those mechanical engineer types around ?
Edit: Ok I stand by my origional derivation
...I've got to stop posting on this topic ! I'm changing my mind every 3 seconds :-S
If you take the follower to be the highest point on the outside of the circle, then your equation is sinosoidal.
If you take the follower to be the point on the outside of the circle directly above the point of rotation, your equation is somewhat different.
I get
[tex]D=\sqrt{R^2-100\sin^2{\theta}}+10\cos{\theta}[/tex]
Which is probably wrong due to some careless mistake... I didn't check it.
Related to Cam -follower displacement as a time function
1. What is a cam-follower displacement?
A cam-follower displacement refers to the movement or displacement of a follower (such as a lever or roller) that is in contact with a rotating cam. The cam-follower displacement can be described as a function of time, as it changes depending on the position of the cam.
2. How is cam-follower displacement measured?
Cam-follower displacement is typically measured using a displacement sensor, such as a linear variable differential transformer (LVDT) or a laser displacement sensor. These sensors can accurately measure small changes in position and convert them into electrical signals.
3. What factors affect cam-follower displacement?
The displacement of a cam-follower is affected by several factors, including the shape and size of the cam, the type and size of the follower, and the speed and direction of the rotation of the cam. The material and lubrication of the cam and follower can also impact displacement.
4. How is cam-follower displacement as a time function useful?
Cam-follower displacement as a time function can provide valuable information about the motion and performance of a cam system. It can be used to analyze the acceleration, velocity, and position of the follower, and can help identify any issues or inefficiencies in the system.
5. Can cam-follower displacement be controlled?
Yes, cam-follower displacement can be controlled by adjusting the shape and size of the cam, the type and size of the follower, and the speed and direction of the cam rotation. By carefully designing and controlling these factors, engineers can achieve precise and desired cam-follower displacements for various applications.
  • Quantum Physics
  • General Math
  • Mechanical Engineering
