Can a^3+b^3+c^3 Equal d^3+e^3 Given Specific Conditions?
  • MHB
  • Thread starter anemone
  • Tags
    Compare
In summary, the problem involves comparing the sums of cubes of five positive real numbers with certain restrictions. One approach is to consider limiting the domain of the variables, such as when they are all greater than 1 or between 0 and 1. Another approach is to eliminate one of the variables and use algebraic manipulations to derive inequalities. However, there is still no clear solution to the problem. Any suggestions or help towards solving it would be appreciated.
anemone
MHB
POTW Director
3,883
115
Problem:
Let $a$, $b$, $c$, $d$ and $e$ be strictly positive real numbers such that:
\(\displaystyle a^2+b^2+c^2=d^2+e^2\)
\(\displaystyle a^4+b^4+c^4=d^4+e^4\)
Compare \(\displaystyle a^3+b^3+c^3\) with \(\displaystyle d^3+e^3\).
I have been exhausting all kinds of algebraic tricks, but I still don't get anywhere near to cracking it, and it is so frustrating not knowing how to solve it...
Any help and/or suggestions toward how to solve this problem is much appreciated.
Mathematics news on Phys.org
Have you considered limiting the Domain?
1) What happens when all of a, b, c, d, e are greater than 1?
2) Everything is 1
3) All are between 0 and 1.
First, I see some restrictions on $a, b$ and $c$. If you eliminate say $e$ from the pair of equations you get
$d^4 - (a^2+b^2+c^2)d^2 + a^2b^2 + a^2c^2 + b^2c^2 = 0$
Since $d$ is real this means that
$(a^2+b^2+c^2)^2-4(a^2b^2 + a^2c^2 + b^2c^2) \ge 0$
or
$a^4+b^4+c^4- 2 a^2b^2- 2 a^2c^2 -2 b^2c^2 \ge 0$
Also note that if $a=b=c = 1$ then we have a contradiction so this can't happen.
2) Everything is 1
Thanks for the hint, tkhunny...and I think we can rule out the possibility when all of them are 1 because
\(\displaystyle 1^2+1^2+1^2 \ne 1^2+1^2\) and \(\displaystyle 1^4+1^4+1^4 \ne 1^4+1^4\)
But for the case where all of the variables are between 0 and 1, do you mean to suggest that we could let, for example a=cosA as another way to approach the problem?
or
Thanks Jester for showing me some insight that I would not have thought of it myself...but, what should I do after that? I am so confused...
I understand the frustration of not being able to solve a problem. However, it is important to approach it with a systematic and logical mindset.
One possible approach to this problem is to use the given information to manipulate the equations. First, we can expand the terms in the first two equations to get:
a^4+2a^2b^2+2a^2c^2+b^4+2b^2c^2+c^4=d^4+2d^2e^2+e^4
Next, we can subtract the second equation from the first to eliminate the higher powers of a, b, and c:
2a^2b^2+2a^2c^2+2b^2c^2=2d^2e^2
We can then divide both sides by 2 to get:
a^2b^2+a^2c^2+b^2c^2=d^2e^2
This equation looks familiar because it is the same as the first given equation. Therefore, we can substitute it in to the second equation to get:
a^4+b^4+c^4=d^4+e^4
This means that a^3+b^3+c^3 and d^3+e^3 are equal, as they are the cubes of the terms in the equation above.
In conclusion, through algebraic manipulation and substitution, we have shown that a^3+b^3+c^3 is equal to d^3+e^3. This means that the two expressions are equal and cannot be compared. Both are simply equal to the sum of the cubes of the terms in the first given equation. I hope this helps in solving the problem.
FAQ: Can a^3+b^3+c^3 Equal d^3+e^3 Given Specific Conditions?
How do you compare a³+b³+c³ with d³+e³?
In order to compare these two expressions, we must first expand them. This will give us a³+b³+c³ and d³+e³. Then, we can group the terms by their powers, so we have (a³+b³)+(c³) and (d³+e³). From here, we can see that the expressions are not identical but they do have some common terms.
What are the common terms in a³+b³+c³ and d³+e³?
The common terms in these two expressions are a³, b³, and c³. These are the terms that have the same power and can be grouped together.
How are a³+b³+c³ and d³+e³ different?
The main difference between these two expressions is the variables used. While a, b, and c are used in the first expression, d and e are used in the second expression. Additionally, the coefficients of each term may also be different.
Can you simplify a³+b³+c³ and d³+e³?
Yes, we can simplify these expressions by using the formula for the sum of cubes. This gives us (a+b+c)(a²-ab+b²)+(d+e)(d²-de+e²).
How can you use a³+b³+c³ and d³+e³ in a real-life scenario?
These expressions can be used in various real-life scenarios, such as calculating the total volume of two different cubes or finding the total amount of money spent on three different items and comparing it to the total amount spent on two other items. They can also be used in engineering or physics equations that involve calculating the sum of cubes.
