I Can a Gaussian distribution be represented as a sum of Dirac Deltas?
A Dirac Delta function can be approximated as a limiting case of a Gaussian distribution as the width approaches zero. Conversely, it is proposed that a Gaussian spectrum can be represented as a weighted sum of Dirac Deltas, where the weights determine the distribution. While any function can be expressed as an integral of Dirac delta functions, a discrete sum representation is not feasible for most functions. However, an approximation using small increments can be made, allowing for a representation that works in an integration sense. This discussion highlights the relationship between Gaussian distributions and Dirac delta functions in mathematical modeling.
tworitdash
We know that Dirac Delta is not a function. However, I just talk about the numerical version of it that we use every day. We can simply represent the Dirac delta function as a limiting case of Gaussian distribution when the width of the distribution ##\sigma->0##.
\delta(x - \mu) = lim_{\sigma -> 0} \frac{1}{\sqrt{2\pi \sigma^2}} e^{\frac{-(x - \mu)^2}{2\sigma^2}}
Is it possible to also say the reverse with a weighted sum of Dirac Deltas to construct a Gaussian spectrum?
\frac{1}{\sqrt{2\pi \sigma^2}} e^{\frac{-(x - mu)^2}{2\sigma^2}} = \sum_{i} w_i \delta(x - i)
Where, somehow the weights ##w_i## constitute how it is distributed (##\sigma##). If yes, how do we decide these weights?
Mathematics news on Phys.org
Any function can be represented as a sum of Dirac delta functions:
Let ##f(x)## be an arbitrary function of ##x##. Then you can represent it as:
##\int f(y) \delta(x-y) dy##
So that's a weighted sum (well, integral) of delta functions.
If you really want a discrete sum, instead of an integral, then it can't be done for most functions. But I guess for some purposes, you can approximate a function by delta functions: Pick a small positive x increment ##\Delta x## and define ##\tilde{f}(x, \Delta x)## by:
##\tilde{f}(x, \Delta x) = \sum_j f(j \Delta x) \delta(x- j\Delta x) \Delta x##
where ##\Delta x## is some small real number. This approximation works in an integration sense: For any other smooth function ##g(x)##, we have:
##lim_{\Delta x \Rightarrow 0} \int \tilde{f}(x, \Delta x) g(x) dx = \int f(x) g(x) dx##
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
