Symmetry777
- 32
- 3
Can a Massless Photon create Mass?
Is Electrostatic Induction a form of “Mass Transfer through the process of Absorption”?
A new star is created. The star generates massive Magnetic Fields. What happens to the hydrogen particles, Nebula, when they are influenced by the Magnetic Field?
If the entity is sending out magnetic fields, photons, massless particles, through the top and the bottom and those fields intersect at a perpendicular angle is Mass being created, aligned?
Are these newly created Mass Particles, Mass attracting Mass, Centripetal force, causing the rotational inertia (angular momentum) of the star?
Electromagnetic Fields are made of Photons.
Photons are Massless Particles.
The question is concerning, “Mass Transfer through the process of Absorption”.
In physics, a charged particle is a particle with an electric charge.
Electric charge is the physical property of matter that causes it to experience a force when placed in an Electromagnetic Field.
“If a Magnetic Field connects between two objects a mechanical coupling between the two objects is created. Such a coupling will couple vibrations, therefore heat will be conducted by the magnetic field.”
“A varying magnetic field (not a constant magnetic field) will induce an electric charge on a particle and can produce heat. For example all the copper atoms in the wire of a stator (electrical generator) produce heat then current.”
The main idea or question is: “Can Massless photon creating Mass?”
If the entity is sending out magnetic fields, photons, massless particles, through the top and the bottom and those fields intersect perpendicular to the entity is Mass being created. Are these newly created Mass Particles, Mass attracts Mass, Centripetal force, causing the rotational inertia (angular momentum) of the star?
Convective heat transfer is one of the major types of heat transfer, and convection is also a major mode of mass transfer.
“In physics, mass–energy equivalence is the concept that the mass of an object or system is a measure of its energy content. For instance, adding any form of energy to any object increases its mass by 1 microgram (and, accordingly, its inertia and weight) even though no matter has been added.”
Thank You
Thank You
