Can a Mechanical Stopper Protect My Apartment Door from Intruders?
  • Thread starter chirhone
  • Tags
    Mechanical
In summary: It's not easy, but it's better than living in constant fear.In summary, this person rented a unit at the 32th floor for 6 months, and the door has only 2 locks. The top has a double lock. The bottom is a normal door lock. The door is only secured by the screws on the frame, and if somebody kicks the door, they can easily break the locks.
  • #36
I still have 3 months of rent left (I may leave early though if COVID-19 transmission is confirmed).
I want to take this opportunity to learn mechanical principles and create a competent defence capability.
In the picture above. Would it be better to get a pole (shown in orange line) to brace against the door bar, or would it be better to put the orange pole directly on the door (without any door bar, I can sell it)? But what would prevent the orange pole from sliding if it is put directly on the door? I can't put any screws or alter the door in any way.
This is the full perspective, and another option:
I can put two poles and a metal plate brace against the door. But how do you design it such that you can disassemble and assemble it easily? without creating a solid welded connection that you would have difficulty removing in the day?
  • #37
Truckers use "load bars" inside the trailer. These are adjustable-length cam-lock devises. Maybe you could put one pad against the door, and the other against your interior door frame. Once the length is adjusted, you just squeeze the lever to extend the pad a little bit to create the tension.
https://www.amazon.com/slp/load-bars/apr3amdx7tquuv6&tag=pfamazon01-20
Likes Tom.G
  • #38
Before I order these load bars (note your url is wrong). I'd like to know if anyone owns one. How strong is it when pressed from the longitudinal side or axis (or when the door is pushed against it)? Remember it is designed for side restraint.
Meanwhile I have temporary solution.
I'd like to compute it. Say a person of 160 lbs run into the door from 10 meters away. What is the force of impact. What units do you use? Joules or KiloNewton? And what Joules/KiloNewton before the door hinges and bar would yield? Can someone give a sample computation? And all formulas involved?
Thank you.
  • #39
If you're worried about people shoulder-barging the door, then you could always hammer some nails through it from your side. Just so they poke through a little.
They won't do it twice.
  • #40
there is grove in the middle door, make brace with 2x4 wood, add rubber on the wood witch make contact with floors
Likes Tom.G
9K
