Can a Model Rocket reach space?
In summary, building a model rocket that can reach space is a difficult task due to the limitations of thrust and time in most model rocket engines. Launching it from a balloon at 30 miles up may not provide a significant advantage. Additionally, the definition of "space" and the requirements for reaching it depend on individual interpretations. To reach low Earth orbit, the minimal velocity needed is 9.4 km/s, which is achievable with a substantial investment of time and money. Some hobbyists have successfully launched rockets to space, but they are no longer considered "model" rockets due to their size and use of custom high-performance engines. The Kerbal Space video program is a useful tool for exploring the limits of low-budget rocketry.
Gbl911
I was wondering if there is a way to build a model rocket that has the capabilities to reach space (not go into orbit though). It would seem to be very difficult to reach space from the ground, but if you launch it from a balloon some 30 miles up, would it be possible, if not, any easier?
Getting a rocket (model or otherwise) into space is a matter of thrust and time.
The engines most model rockets have have enough thrust, but not for enough time, and engines that do have enough thrust for enough time can't (yet) be made small and light enough to be used in model rockets.
I'm not an aerospace engineer or a rocket scientist, though, so you may want to get a second opinion.
Thanks. Though would it have enough thrust for enough time if you launched it from a balloon?
First, it depends on what your definition of "model rocket" is. You could certainly design and build a rocket yourself that could reach space, though only with a substantial investment of time and money, and at that point it would cease being a "model" rocket by most definitions.
Second, placing it on a balloon and launching it from 30 miles up changes the escape velocity from 11.2 km/s to 11.1 km/s, so there really isn't a whole lot to be gained by placing it on the balloon.
Likes Dr.Physics
If OP doesn't want it to orbit, it doesn't need to reach escape velocity...
The question here is, where do you define "space"? At what altitude?
The OP did not exclude orbit. I think getting to "space" for the layman from Earth commonly means orbit.
Specific orbital energy might be a good place to start. To place any object in low Earth orbit requires the addition of 32.8 MJ/kg to the object beyond its energy at the Earth's surface, not counting any energy lost to other than the final object in orbit. Energy is either potential energy (mgh) or kinetic energy (mv2/2). As an example, the velocity for the all kinetic energy case is ~8.1 km/sec.
Energy density of carried hydrogen and oxygen fuel is 16 MJ/kg, so some 2 kg of, say, H2-O2 fuel is required per kg of orbital mass using a perfectly efficient engine, then more fuel is required to lift the fuel and the apparatus for using the fuel, so that the compounding effect is apparent.
The advantage is the avoidance of lost energy to atmospheric drag on ascent. Drag power is proportional to air density, which reduces from sea level by a factor of ~1000 at 30 miles/50km.
Likes kingburrito666
What about the reduced time it would take to get to space from 30 miles up. And the reduced drag.
I would say there are two major schools of thought:
1) Reaching orbit. Obviously a model rocket, with current technology and pricing, is out of the realm of possibility.
2) Reaching the Karman Line, ~100 km up, which is an internationally agreed upon boundary between Earth's atmosphere and "space". This can be, and has been, done. Though, I'm not sure I'd call these guys "hobbyists" at this scale... http://www.hobbyspace.com/Rocketry/Advanced/records.html
OP, if you are talking about orbit, 30 Miles isn't going to help you very much at all...It may help a bit with drag early on and reduce some fuel costs, but you're not very close to orbit at that point, and you still need to get your horizontal (tangent) velocity up high enough to orbit that's still a TON of delta V.
Ok, so how exactly large would this rocket have to be to get into orbit with no other payload than itself? And at this point you wouldn't be using model rocket engines anymore.
See the hobbyspace rocket examples provide to you above. They reached space, or close to it, and appear to be ~3-5M long, maybe ~0.1M diameter
Typically, you'd look at something more like 8-10 inch diameter (~0.25m or so), but your length seems about right (probably closer to the long end). They also contain custom made high performance solid rocket motors that put out in excess of a thousand pounds of thrust for 10-15 seconds, so they're not really what you would consider "model" rockets anymore.
cjl said:
...for 10-15 seconds, so they're not really what you would consider "model" rockets anymore.
Somebody reportedly got to space (Karman) from that hobbyist group, so somebody must have flown much longer.
It occurs to me that the Kerbal Space video program would much more quickly satisfy curiously about the limits of low budget rocketry than, say, traveling to Nevada for a high altitude launch. Apparently JPL engineers are obsessed with the thing, and Elon Musk is a fan.
https://kerbalspaceprogram.com/
Likes kingburrito666 and Dr.Physics
Minimal low Earth orbital velocity is only 9.4 km/s. You don't need to achieve escape velocity to put something in LEO.
Here you can see a bunch of undergrads launching a rocket from a balloon. You can ascertain the dimensions of the thing, and appreciate some of the issues that need to be overcome.
Oh, the flight is much longer. The motor only burns for 10-15 seconds, and the majority of the flight is an unpowered coast.
You want to also launch in the direction of rotation of the Earth to get an added incremental benefit.
Only if you want to achieve orbit. If you simply want to reach space (>100km altitude), straight up is the easiest way to do it.
Related to Can a Model Rocket reach space?
1. How high can a model rocket go?
The maximum altitude a model rocket can reach depends on various factors such as the size and weight of the rocket, the type and power of the engine, and the weather conditions. Most model rockets can reach heights of 1000 feet or more.
2. Is it possible for a model rocket to reach space?
Technically, space is defined as an altitude of 62 miles or 100 kilometers from the Earth's surface. Most model rockets are not capable of reaching such high altitudes and are limited to 1000 feet or less. However, advanced model rockets with powerful engines can reach altitudes of up to 10 miles.
3. What is the highest altitude a model rocket has ever reached?
The current record for the highest altitude reached by a model rocket is 144 miles or 233 kilometers. This record was set by a team of high school students in 2017 with a rocket powered by a hybrid engine.
4. Are there any safety concerns when launching a model rocket to high altitudes?
Yes, there are certain safety concerns when launching a model rocket to high altitudes. It is important to follow all safety guidelines and regulations set by the National Association of Rocketry. The rocket should also be equipped with a recovery system to ensure it returns safely to the ground.
5. What is the purpose of launching a model rocket to high altitudes?
Launching a model rocket to high altitudes can serve both educational and recreational purposes. It allows individuals to learn about rocketry, aerodynamics, and other scientific concepts. It can also be a fun and challenging hobby for those who are interested in building and launching their own rockets.
  • Aerospace Engineering
