Can a polynomial ever just have 2 terms?
In summary, a polynomial is an expression consisting of variables and coefficients, involving only addition, subtraction, multiplication, and non-negative integer exponents. It can have as few as 1 term (monomial) or as many as desired. The number of terms does not determine whether it is a polynomial. However, polynomials in one variable have special names based on their order, such as quadratic, cubic, quartic, etc. Division is allowed within a polynomial as long as it is expressed as multiplication. The use of "textspeak" abbreviations should be avoided in order to appeal to a wider audience.
OMGMathPLS
64
Or does it always have to have MORE THAN 2 like
x^2 +x^2 -4a polynomial can never be
x^2 - x-^3
Right?
Mathematics news on Phys.org
i don't fully understand your question but yes there can be x^2 and x^3 and x^4 and x^5 etc...
Whoops. Sorry I mean
A polynomial can never be
term +/-/*/divide term (only 2 terms)
it must be
term term term
at least 3 right? To be considered a polynomial?
In mathematics, a polynomial is an expression consisting of variables (or indeterminates) and coefficients, that involves only the operations of addition, subtraction, multiplication, and non-negative integer exponents.
A polynomial can have as few as 1 term, which is a monomial. Two terms and the polynomial can also be called a binomial, and 3 terms is a trinomial. I tend to use the special names for smaller polynomials though. Also, polynomials in one variable have special names related to the order. Instead of using trinomial, I would call $x^2+x+1$ a quadratic, meaning it is a second order polynomial, because the largest exponent is 2.
With regard to order, there are constant, linear, quadratic, cubic, quartic, quintic, etc. polynomials.
well you can have something like $x^2-4$ which is only two terms and a polynomial CAN include division like $x^2/2...$
Oh ok. Thanks.
The Issac Newton picture fits you.
lol mark is isaac Newton.
ineedhelpnow said:
...a polynomial CAN include division like $x^2/2...$
Good point, but we could also view this as multiplication by 1/2. I think the restriction of not allowing division would be as in the following example:
\(\displaystyle \frac{x^2+x+1}{7x+2}\)
is not a polynomial, whereas,
\(\displaystyle \left(x^2+x+1\right)(7x+2)\)
is a polynomial, written in factored form.
OMGMathPLS said:
Oh ok. Thanks.
Hey, I never noticed that, but Geddy Lee does bear a certain resemblance to Newton. (Smirk)
Lol
OMGMathPLS said:
Lol
Just so you know for the future, we try to discourage the use of "textspeak" abbreviations, simply because we want to appeal to as wide a global audience as possible, and many folks around the world may not be familiar with these abbreviations and would be left wondering what it means. :D
Soooooo... Can we drop apples on him?
-Dan
FAQ: Can a polynomial ever just have 2 terms?
Can a polynomial with only two terms be considered a polynomial?
Yes, a polynomial is defined as an expression consisting of variables and coefficients, combined using addition, subtraction, and multiplication. Therefore, a polynomial with two terms still fits the definition.
Can a polynomial with only two terms have exponents?
Yes, one or both of the terms in a polynomial can have exponents. For example, the polynomial 3x^2 + 5x is a valid polynomial with only two terms.
How do you determine the degree of a polynomial with only two terms?
The degree of a polynomial is determined by the highest exponent in the polynomial. In a polynomial with two terms, the degree will be the exponent of the term with the highest exponent.
Is it possible for a polynomial with only two terms to have a negative exponent?
Yes, a polynomial with two terms can have a negative exponent. For example, the polynomial 2x^-3 + 4x^2 is a valid polynomial with two terms and a negative exponent.
Can a polynomial with only two terms be simplified?
Yes, a polynomial with two terms can be simplified by combining like terms, if any. For example, the polynomial 3x + 4x can be simplified to 7x.
