Can a real image be formed by a virtual image?
In summary: This means that the distinction between real and virtual images is relative to each individual lens. A converging lens can form a virtual object if the object is within its focal length, but the light entering or leaving the lens is still converging, making the object and image virtual as far as that lens is concerned.
Samuelriesterer
110
That is, take the virtual image as the object for a second lens?
Yes, that is quite common practice, e.g. in microscopes.
I thought microscopes form the real image from the objective lens, then the viewing lens forms a virtual image from that real image. I was looking for the reverse.
Sure. You can place a diverging lens as the first lens in an optical system and then use a focusing lens to focus the light into a real image.
Why not? It happens in your EYE, when you are wearing specs for short sight. or long sight. The description of Real of Virtual image is really only relevant when considering the overall behaviour of an optical system.
The problem here seems to be the old one of Classification getting in the way of Understanding. Who givesa about the name you can give an image within an optical system? When you are ready for it, study the systems for calculating the result of a complicated system of lenses (sign conventions vary from system to system`). Google "sign conventions" and see what you get.
Example: Object at x = 0, lens #1 at x = 40, with focal length f1 = 20. The image is at x = 80, right?
(Note "x" means position along the x-axis, i.e. optical axis, not object or image distance in the thin-lens equation.)
Now put lens #2 at x = 50, with focal length f2 = 20. The image produced by lens #1 is the virtual object for lens #2, with object distance -30. Where is the image?
Likes Samuelriesterer
jtbell said:
Where is the image?
I find this topic entirely confusing so can you verify:
##s'_1 = \frac{f_1 s_1}{s_1 - f_1} = \frac{(20)(40)}{40-20} = 40##
##s_2 = (50-40) - s'_1 = 10 - 40 = -30##
##s'_2 = \frac{f_2 s_2}{s_2 - f_2} = \frac{(-20)(-30)}{-20+30} = -60##
You need to distinguish carefully between the position x of an object, image, or lens, and the distance between a lens and an object (s) or an image (s'). A distance is the difference between two positions. It helps to draw a diagram.
This is the distance of image #1 from lens #1. Lens #1 is located at x = 40. What is x for image #1?
This actually is the correct value for s2, but I prefer to think of it as the difference between the position (x) of lens #2 and the position (x) of image #1, which is the object for lens #2.
I specified the focal length of lens #2 as 20, not -20.
The x position for image #1 is x = 80.
Ok:
##s'_2 = \frac{f_2 s_2}{s_2 - f_2} = \frac{(20)(-30)}{20+30} = 12##
So the final image distance is 12, and its x position is: x = 62?
You got it! :biggrin:
So for lens #2, you have a virtual object, but a real image.
Can you please clarify because it looks like the first image formed by the first lens is real because the object is outside the focal length.
But the rays never get to the first image, because they are intercepted by the second lens first. So if you put a screen at the position of the first image (with the second lens in place) you will not see the image.
In any case, the distinction between real and virtual image is not very helpful.
OK I think I get it now. Yea it seems misleading that the virtual image is the object for the second lens because the rays never make it there. I guess I was picturing something different as if rays eminated from the virtual image, which of course is impossible. That is why I was struggling with the possibility of this scenerio.
Yes, the image formed by the first lens is real. However, it acts as a virtual object for the second lens. "Real" and "virtual" are relative to each individual lens.
One way to keep things straight is to look at whether the light is converging or diverging as it enters or leaves the lens. If the light entering a lens is diverging, the object is real, as far as that lens is concerned. If the light entering is converging, the object is virtual. If the light leaving a lens is converging, the image is real, as far as that lens is concerned. If the light leaving is diverging, the image is virtual.
Notice what happens if we leave the original object and lens #1 where they are, in our example, but move lens #2 to x = 100, beyond the image formed by lens #1. Now that image becomes a real object for lens #2, because the light that was converging towards the first image has passed through it and is now diverging when it reaches lens #2.
What does this mean because a converging lens can still form a virtual object if the object is within the focal length.
Related to Can a real image be formed by a virtual image?
1. What is a real image and a virtual image?
A real image is an image that is formed by the actual convergence of light rays at a specific point, while a virtual image is an image that is perceived to be formed by the extension of light rays from an object.
2. Can a real image be formed by a virtual image?
No, a real image cannot be formed by a virtual image. This is because a real image is formed by the actual convergence of light rays, while a virtual image is only perceived to be formed by the extension of light rays.
3. How can you tell if an image is real or virtual?
An image is real if it can be projected onto a screen, while a virtual image cannot be projected onto a screen. Additionally, if the image can be seen from different angles, it is most likely a virtual image.
4. What is the difference between a real and virtual image in terms of magnification?
A real image has a positive magnification, meaning it is enlarged compared to the object, while a virtual image has a negative magnification, meaning it is reduced in size compared to the object.
5. Can a virtual image be captured by a camera?
No, a virtual image cannot be captured by a camera. This is because a virtual image is only perceived to be formed by the extension of light rays and does not actually exist in physical space.
  • Other Physics Topics
13K
16K
18K
  • Optics
20K
