Can a set include negative infinity and be bounded below
In summary, the conversation discusses the proof that the set {##x \epsilon \mathbb{R} : x^2 \ge 1##} is not bounded below. The proof is done by contradiction, showing that for any real number m, there exists an x such that x < m. This contradicts the definition of a lower bound, therefore the set is not bounded below. The discussion also addresses the misconception that the set includes negative infinity, when in fact it is a subset of the real numbers and does not include −∞.
fishturtle1
394
82
Prove that {##x \epsilon \mathbb{R} : x^2 \ge 1##} is "not" bounded below.
EDIT: I Looked closely and realized there is a "not" that we all had to write in...sorry if you lost some time..
Defintion: We say a nonempty subset ##A## of ##\mathbb{R}## is bounded below, if there is a real number ##m## such that ##m \le x## for all ##x \epsilon A##. We call such an ##m## an lower bound of ##A##.
I don't think this is bounded below.
Proof: This will be a proof by contradiction. Suppose ##m## is a lower bound of the set A ={##x \epsilon \mathbb{R} : x^2 \ge 1##}. Then ##m \le x## for all ##x \epsilon A##. But ##m - 1 < m## and ##m - 1 \epsilon A##.(Not sure how to prove that last statement). Therefore ##m > (m-1)## and ##(m-1) \epsilon A##. Therefore m is not a lower bound, a contradiction. We conclude there does not exist a lower bound of A and A is not bounded below. []
Edit: in class we proved that the statement was True and had 3 cases but I don't see why the proof makes sense.
Consider 3 cases:
Case 1: Let ##m < -1## Let ##x = m - 1##. Then ##x = m - 1 < m##.
Case 2: Let ##m \epsilon [-1,1]##. Let ##x = m-4##. Then ##x = m - 4 < m##.
Case 3: Let ##m > 1##. Then ##x = -m##. Then ##x = -m < m##.
So we showed for any real number m, there exists an x such that x < m. Which I guess fulfills the definition. But I'm saying since the ##A## is going toward negative infinity, then I can always find a ##k## such that ##k < x##.
Are you considering the negative numbers x where x2 ≥ 1? How low can those go?
To negative infinity
Sorry, I didn't realize why there were three cases in the proof and didn't notice exactly what you were asking. Yes, your intuition is right that you can get as great a negative number as you want, but the complication of which region m is in was handled in 3 cases.
He could have just said something like a = -|m|-200 ∈ A and a < m. That would have taken care of all cases.
So basically, if a = -|m| - 200 ##\epsilon## A and a < m, it follows that there is no lower bound, because for all elements m ##\epsilon## A, there exists an a ##\epsilon## A, such that a < m.
edit: had some questions.. but rereading your post a few times answered them...
Yes. And a = -|m| - 200 << -1 is always such a large negative number that it is guaranteed to be in A and lower than m. So there is no need to have 3 cases.
Consider 3 cases:
The title of your thread is misleading - or worse.
"Can a set include negative infinity and be bounded below" ?​
The set you describe is a subset of ℝ, the real numbers.
Neither −∞ , nor ∞ is a real number, so your set does not include −∞ .
That is my mistake, I see that −∞ is not in (−∞, ∞). What I meant was "If an interval is approaching −∞, can it also be bounded below?". I'm sorry for the carelessness.
Related to Can a set include negative infinity and be bounded below
1. Can a set include negative infinity and still be bounded below?
Yes, a set can include negative infinity and still be bounded below. This means that there is a lower limit to the set, but it does not necessarily include all negative numbers.
2. Is negative infinity considered a number or symbol in a set?
Negative infinity is considered a symbol in a set, rather than a number. It represents a limit or boundary, rather than a specific numerical value.
3. How can a set be bounded below if it includes negative infinity?
A set can be bounded below if it includes negative infinity by having a lower limit that is greater than negative infinity. This means that negative infinity is not included in the set, but is still a theoretical boundary.
4. Does including negative infinity in a set affect its cardinality?
No, including negative infinity in a set does not affect its cardinality. The cardinality of a set is determined by the number of elements it contains, and negative infinity is not considered an element in this context.
5. Can a set be bounded below without including negative infinity?
Yes, a set can be bounded below without including negative infinity. It can have a lower limit that is a specific number or any other symbol. Including negative infinity is not a requirement for a set to be bounded below.
