Can a silver atom be physisorbed to its surface?
In summary, the conversation revolves around the concept of activation energy for chemisorption and how it relates to the interaction of atoms with a solid surface, particularly in metals. The discussion also touches on the factors that affect the strength of this activation energy, including the history of the surface.
rrg92
Hi all,If there is activation energy for chemisorption, then an atom with insufficient energy to overcome that barrier will remain physisorbed to the surface via van der Waals forces. I would like to further understand this activation energy in terms of, for example, the overlap of electron wavefunctions that repels a metal atom from the surface, until eventually these electrons are forced to higher energy levels and become delocalized (… if that’s how it works to begin with). Would that mean a fraction of the surface atoms are chemisorbed, and the remaining fraction is physisorbed? What is the strength of this activation energy?
You say, "silver." On a silver surface? It's going to depend upon the history of the surface plus ... ?
It doesn't have to be silver, it was just an example. My question is for the interaction of an atom with its condensed solid phase, specifically for metals.
Related to Can a silver atom be physisorbed to its surface?
1. Can a silver atom be physisorbed to its surface?
Yes, a silver atom can be physisorbed to its surface. Physisorption is the process of weakly binding molecules or atoms to a surface through van der Waals forces. Silver is a noble metal with a high surface energy, making it prone to physisorption.
2. What is the difference between physisorption and chemisorption?
Physisorption involves weak interactions between the adsorbate (molecule or atom) and the surface, while chemisorption involves stronger chemical bonds. Physisorption is reversible and does not result in a chemical reaction, while chemisorption often leads to a chemical reaction and irreversible bonding.
3. How does temperature affect physisorption of silver atoms?
As temperature increases, the energy of the atoms also increases, making them more likely to overcome the weak van der Waals forces and desorb from the surface. Therefore, higher temperatures can decrease the amount of physisorption of silver atoms on a surface.
4. Can physisorption of silver atoms be detected experimentally?
Yes, physisorption of silver atoms can be detected experimentally through various techniques such as surface plasmon resonance, X-ray photoelectron spectroscopy, and atomic force microscopy. These methods can measure changes in surface properties or directly visualize the adsorbed atoms.
5. What are some potential applications of physisorption of silver atoms?
The physisorption of silver atoms has various applications in fields such as catalysis, sensors, and nanotechnology. Physisorbed silver atoms can act as catalysts for chemical reactions, be used to detect small concentrations of gases or biomolecules, and serve as building blocks for nanoscale devices and structures.
  • Atomic and Condensed Matter
  • Classical Physics
  • Other Physics Topics
