Can a solar sail be accelerated 20% speed of light
In summary: Not solar wind, but rather light from powerful lasers would be the propulsion source. In the 1970s proposal I mentioned in #7. they talked of lasers in close solar orbit that would accelerate the sail until it got out to about the orbit of Jupiter, achieving 1/3 light speed. Of course the proposal was speculative, not practical.That's correct.
Astronomy news on Phys.org
What would happen?
No. not in a reasonable timeframe. However, A light sail could. We would need to shoot lots of lasers at the sail. Solar luminosity decreases with distance.
wolram said:
This seems over optimistic to me but is 20% the speed of light feasible?
If you make the sail thin enough, everything gets possible - apart from building such a sail.
That's exactly right. In the 1970s, I saw a proposal to build a solar sail the size of The Moon, but weighing only 1 gram. It would be made of aluminum foil only two atoms thick. IMO, deploying it and holding it in shape and orientation would be even more difficult than building it.
Back to the OP. Your question can't be answered without specifying the size and mass of the sail and the payload, and the mission.
That's not true, you can't make a sail go faster than the wind. The solar wind travels around a million miles an hour, so that's where it'd max out. Plus a small boost from light pressure, but that'd be negligible by comparison wouldn't it?
Edit: I just realized that to achieve 1/3 light speed with uniform acceleration from solar orbit to Jupiter's orbit, the duration of the acceleration phase is only about 4 hours. Even allowing for a more accurate calculation, the lasers need to survive for only a very short time.
Likes newjerseyrunner
So a foil in front of a series of nuclear blasts? Maybe place the nukes in a line and trigger them as the foil/plasma passes?
Starshot is claiming 4.7% of light speed. They are assuming a functional graphene sheet, a reflective atomic monolayer coating, and a computer printed into that sheet and layer.
wouldn't the smallest of friction from solar dust be an issue for anything that has mass made from earthly materials while traveling at that speed? or is this 20%*c the estimate based on materials and friction?
An article in Scientific American had 1 laser array and at least one rocket launch. Each probe weighs a few grams. So each launch package contains thousands of probes. The laser array accelerates one probe for a few minutes. The probes can be sent separately. You can do one probe a day or several per hour. Most of the probes will be mangled or destroyed before getting to Alpha Centuari. The hope is that more than one of the thousands sent are still able to send back data.
The sail does not need to work on the other end if it is a flyby. If they plan to slow down then the sail has to fold/roll into something like a needle. One of them might still work with some holes.
Finding out how much dust is between here and Alpha Centuari would be information gain.
Actually solar radiation pressure is three or four orders of magnitude higher than the pressure of the solar wind (at 1 AU)--see for example Wikipedia.
How would the nuclear explosives get there?
how would the nuclear explosives get there?
Hmm. Could you use them within the solar system and coast the rest of the way?
So the trip is going to be slow anyway, first you're going to set the explosives off on their way then send the "vehicle" off hope all the time that you've got the orbital mechanics worked out correctly so the "vehicle" passes very close to the explosive, but not too close that the "sail" is damaged and not too far that the explosion is ineffective.
Has the speed of say 10x5g object been calculated with say 102 x 5m sail when it gets out of the heliosphere?
Related to Can a solar sail be accelerated 20% speed of light
1. How does a solar sail work?
A solar sail uses the pressure of sunlight to propel a spacecraft forward. The sail is made of a highly reflective material that reflects sunlight and transfers its momentum to the sail, causing it to move forward.
2. Can a solar sail be accelerated to 20% the speed of light?
In theory, yes, a solar sail can be accelerated to 20% the speed of light. However, in practice, it would require a very large sail and a long amount of time to reach such high speeds.
3. What are the limitations of a solar sail's acceleration?
The main limitation of a solar sail's acceleration is the amount of sunlight available. The farther away from the sun a spacecraft is, the less sunlight it receives, which limits the amount of acceleration it can achieve. Additionally, the size and weight of the sail also play a role in its acceleration.
4. How does a solar sail compare to traditional rocket propulsion?
Solar sails offer a more efficient and sustainable form of propulsion compared to traditional rocket engines. Solar sails do not require any fuel and can continue to accelerate as long as they are exposed to sunlight. However, they are limited by the amount of sunlight available and may take longer to reach high speeds compared to traditional rockets.
5. Are there any real-world applications for solar sails?
Yes, solar sails have been used in space exploration missions, such as Japan's IKAROS and NASA's NanoSail-D2. They have also been proposed for potential applications in deep space travel and asteroid deflection. However, more research and development is needed to make solar sails a more practical option for space travel.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
