Can a spherically symmetric antenna radiate?
In summary, the conversation discusses the concept of spherical radiation in the context of college physics. It is stated that an antenna cannot radiate spherically symmetrical due to the conservation of charge, which would violate the conservation of charge. This restriction also leads to a reduction in the degrees of freedom of the electric radiation field. The conversation also mentions the possibility of describing radiation with orthogonal E and B fields transversal to the direction of motion, which is also a result of the conservation of charge.
Loren Booda
3,125
Seems to me I was taught in college physics that either a spherical "antenna" could not radiate or an antenna could not radiate spherically. Are either true? How about for an acoustical spherical membrane? For quadrupole mediated gravity?
It's the second one: "An antenna can not radiate spherically symmetrical"
The reason is ultimately the conservation of charge. If you could "switch"
a charge on and off then you would have perfectly spherical radiation.
This would however violate the conservation of charge given by [itex]\partial_\mu J^\mu=0[/itex],
where J is the 4-vector current. The radiation would be longitudinally
polarized, with E in the direction of the motion and without a B component.
The fact that we always can describe radiation by orthogonal E and B
fields transversal to the direction of the motion is ultimately also the
result of the conservation of charge: [itex]\partial_\mu J^\mu=0[/itex] leads to [itex]\partial_\mu A^\mu=0[/itex],
which is the conservation of the potential field. This restriction then leads
Regards, Hans
The statement that a spherically symmetric antenna cannot radiate is not entirely accurate. While it is true that a perfectly spherical antenna cannot radiate due to symmetry, there are ways to break this symmetry and allow for radiation. For example, an antenna with a dipole or monopole element placed off-center on a spherical surface can radiate in a non-spherical pattern.
In the case of an acoustical spherical membrane, it is possible for it to radiate sound waves in a spherical pattern. This is because the membrane is not perfectly spherical and has a non-symmetric mode of vibration.
For quadrupole mediated gravity, the concept of radiation may not apply in the same way as it does for electromagnetic radiation. However, there are theories that suggest gravitational waves can be emitted from a spherically symmetric object, such as a rotating black hole. So in this case, it is possible for a spherically symmetric object to radiate in a sense.
Overall, while a perfectly spherical antenna may not be able to radiate, there are ways to break this symmetry and allow for radiation. And in other fields such as acoustics and gravity, the concept of radiation may have different implications and behaviors.
Related to Can a spherically symmetric antenna radiate?
1. Can a spherically symmetric antenna radiate?
Yes, a spherically symmetric antenna can radiate electromagnetic waves.
2. How does a spherically symmetric antenna radiate?
A spherically symmetric antenna radiates by converting electrical energy into electromagnetic radiation. The antenna is designed in such a way that the electric current flowing through it creates a changing electric field, which in turn generates a changing magnetic field. These changing fields then combine to form an electromagnetic wave that is emitted into the surrounding space.
3. What factors affect the radiation pattern of a spherically symmetric antenna?
The radiation pattern of a spherically symmetric antenna is affected by various factors such as the antenna's size, shape, and orientation. Additionally, the frequency of the input signal and the material used to construct the antenna can also impact the radiation pattern.
4. Can a spherically symmetric antenna be used for directional communication?
Yes, a spherically symmetric antenna can be used for directional communication by controlling the shape and orientation of the antenna. By adjusting these factors, the antenna can focus the radiation pattern in a specific direction, allowing for more efficient communication with a targeted receiver.
5. What is the difference between a spherically symmetric antenna and a dipole antenna?
A spherically symmetric antenna is designed to radiate electromagnetic waves equally in all directions, while a dipole antenna is designed to radiate in a specific direction. Additionally, a spherically symmetric antenna has a spherical shape, while a dipole antenna typically has a linear shape. The two types of antennas also have different radiation patterns and efficiencies.
  • Electrical Engineering
  • Quantum Physics
  • Electromagnetism
