Can a straight wire be a self inductor?
In summary, a loop of wire carrying current can act as a self-inductor, as it induces a current in the opposite direction to oppose changes in the magnetic field. A straight wire can also have self-inductance. Changing the strength of the magnetic field can induce current, and the definition of magnetic flux is the magnetic field passing through a surface. Maxwell's equations use symbols for current density and charge density, and the differential form is the easiest way to understand the relationships between them.
overtak3n
27
I hope this is posted in the correct thread.
When I was still in my physics class, we learned that a loop of wire with current can act as a self inductor.
Just to refresh my memory:
A loop of wire carrying current has a magnetic field around it due to current, however if the current changes, the magnetic field changes. This change in magnetic field makes the wire induce a current in the direction such that it opposes the change in magnetic field. Thus the induced current is in the direction opposite of the direction of the change in current.
Thus a loop of wire is a self-inductor since it does not require any external magnetic field to induce a current, it just requires a change in current which causes a change in magnetic field.
1) Is this correct? Please correct me if I am wrong anywhere, since I'm just refreshing my memory.
2) My question: While a loop of wire can be a self-inductor, can a straight wire also be a self-inductor?
3) Another question: I also learned current can be induced if there is a magnetic field and a loop of wire rotates, or its area changes. In addition, current is induced if the magnetic field changes.
By "magnetic field changes" does that mean the strength of the magnetic field changes?
Hopefully this can be answered in simple terms.
Thanks.
Inductance happens when there are charges in a changing magnetic field.
If a wire loops back on itself, and it has a current, then part of the wire is in the magnetic field of another part of the wire. This does not happen for straight wires.
... it means the magnetic flux changes... this usually means the magnetic field changes.
When you are first introduced the electricity and magnetism, it is taught as a collection of separate formulae and phenomena. As you advance, the different ideas get unified. To get a more complete picture, look at Maxwell's equations.
Thank you for the response.
That makes sense. In a loop of wire, for example, the opposite side of the wire of one part would create what would be like an external magnetic field to that part of wire. That's how I understand your explanation.
To your response with regard to changing magnetic field: This leads me to another question: Will changing the strength of the magnetic field induce current?
"2) My question: While a loop of wire can be a self-inductor, can a straight wire also be a self-inductor?"
A straight wire does have self inductance.
Thank you. Seems to contradict what Simon said. Hmm which answer is correct?
I don't think it is contradictory - I just left out a situation ;)
Meir's answer is part of that "more complete picture" that I mentioned at the end of my reply.
What education level do you need the answers for?
Yes - this is how generators work.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html
A time-varying magnetic field produces an electric field.
A time varying electric field produces a magnetic field.
The self inductance of a straight wire of length s and diameter d in mm, is LuF = 0.2 * s * ( Loge( 4 * s / d ) – ¾ )
So a changing magnetic field doesn't necessarily mean changing magnetic flux, it could mean changing magnetic field strength? Are those the same thing, no?
By time varying electric field, are you referring to current?
As for which education level, college but I just wanted simple answers that answer the question :biggrin:
1. What is the definition of a magnetic field.
2. No. A time varying electric may exist in a region of space where there are no charges.
3. What counts as simple depends on the education level ;) Have you had a look at Maxwells eqs yet?
1. Space around which there exists a magnetic force (I'm assuming it can vary in strength too)
3. Yep.
1. Erm OK for now, consider: "What is the definition of magnetic flux?"
3. In maxwell's equatons, the symbol "j" is the current density. You'll see equations with thatn in it, as well as time varying E and B.
2. In maxwel, ##\rho## is the charge density - you can still get sensible solutions for ##\rho=0##.
The easiest form to see the relations and appreciate how they hang together is the differential form.
1. I think it's the magnetic field passing through a surface.
Thank you for helping. The physics course I took only required integral calculus. I still need to complete my math courses before I fully understand differential equations :cool:
So you can see that magnetic field and magnetic flux are related.
Do you know the mathematical relation that links them?
... once you have that, you should be able to answer your own question ;)
http://en.wikipedia.org/wiki/Magnetic_flux
You should still be able to read the differential form ... where ##\Delta x## is a change in x, and ##\delta x## is a small change in x, you read the "dx" notation to be an extremely small change in x. i.e. acceleration is the rate if change of velocity ... which is written: $$\vec a =\frac{d\vec v}{dt}$$ ... the integral form would be $$\vec v = \int \vec a(t) \; dt$$ ... you should be able to get the idea by replacing the d's with deltas.
In Maxwell's equations the symbol ##\nabla## is used a lot - that just denotes a change in the variable with an extremely small change in space.
But you will need to complete your math courses to have a chance to understand some of the connections between electricity and magnetism yeah.
Thank you Simon.
Is the symbol ∇ used in Maxwell's equations the same as the symbol ∇ used in calculus for gradient?
Pretty much. In Cartesian coordinates: $$\vec \nabla = \begin{pmatrix}\frac{\partial}{\partial x}\\ \frac{\partial}{\partial y}\\ \frac{\partial}{\partial z} \end{pmatrix}$$... which allows it to be used with dot and cross products on vector functions. Recall ##\vec E = E_x(x,y,z)\hat\imath + E_y(x,y,z)\hat\jmath + E_z(x,y,z)\hat k## ... which is kinda difficult to use the grad operation on.
See: http://en.wikipedia.org/wiki/Del
FAQ: Can a straight wire be a self inductor?
1. Can a straight wire be a self inductor?
Yes, a straight wire can function as a self-inductor. An inductor is a type of passive electronic component that resists changes in current flow. A straight wire can act as an inductor if it is wound into a coil, creating a magnetic field when an electric current flows through it.
2. How does a straight wire act as a self inductor?
A straight wire acts as a self-inductor by creating a magnetic field when an electric current flows through it. This magnetic field resists changes in the current flow, which is the defining characteristic of an inductor.
3. What are the applications of a self-inductor made from a straight wire?
A self-inductor made from a straight wire has many practical applications in electronics. It is commonly used in circuit designs to filter out unwanted frequencies, store energy, and regulate voltage.
4. Is a self-inductor made from a straight wire better than other types of inductors?
The effectiveness of a self-inductor made from a straight wire depends on the specific application. In some cases, other types of inductors, such as toroidal or solenoid inductors, may be more suitable. It is essential to consider factors such as size, cost, and performance when selecting an inductor for a particular use.
5. Can a straight wire be used as a self-inductor in high-power applications?
Yes, a straight wire can be used as a self-inductor in high-power applications. However, in these cases, it may be necessary to use thicker wire or multiple coils to handle the higher currents and prevent overheating. Other types of inductors may also be more suitable for high-power applications due to their design and materials.
