B Can a thunderstorm affect a satellite in low earth orbit?
Thunderstorms generate strong static electric charges and magnetic fields, but their impact on satellites in low Earth orbit (LEO) is minimal. Satellites, traveling at high speeds and positioned about 90 miles above thunderstorms, only pass over them for a brief period. The ionosphere, which lies between 100 km and 300 km, effectively shields satellites from electromagnetic interactions with thunderstorms. Additionally, the solar wind poses a greater threat to LEO satellites than thunderstorms do. Overall, while thunderstorms can produce detectable magnetic forces, they do not significantly affect satellite operations.
Wo Wala Moiz
Clouds build up strong static electric charges. Magnetism is an emergent phenomenon of the length contraction of electric fields. Due to the strength of EM interaction, even very slow movement can result in strong magnetic fields, such as that caused by electrons moving at drift speed through the wires of electromagnets.
So, wouldn't satellites be subject to easily detectable magnetic forces from clouds due to their high speed around the earth, if they were to pass over a thunderstorm?
Astronomy news on Phys.org
Well ... sure.
But "detect" and "affect" are very different animals.
Also note: a satellite, travelling at 5 miles per second, will only be over a typical thunderstorm for about 6 seconds. And it's about 90 miles above it.
Thunderstorms disturb the atmosphere up to about 15 km.
LEO satellites orbit well above that, at an altitude above 400 km.
The ionosphere is a conductive layer of the atmosphere, that lies between about 100 km and 300 km above the surface. The ionosphere will significantly attenuate and shield the electromagnetic interactions between thunderstorms and satellites.
The solar wind interacts with the ionosphere, and causes more problems for LEO satellites than do thunderstorms.
Likes Astranut, Klystron, berkeman and 1 other person
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
