Can a time-varying magnetic field pass a metal sheet?
In summary: I can understand what you are trying to say?In the longitudinal direction it is like a short parallel wire but does not form a compete circuit, so no current can flow. As no current flows, there is no shielding effect. A short parallel wire? I don't understand what you are trying to say.
goodphy
216
Hello.
I'm using CT (Current Transformer) to measure the current flowing on the power line. The frequency of the current is 13.56 MHz. CT appeared to be metal-shielded (This metal case of CT may be grounded when CT is used).
CT has a toroidal shape and the power line under the measurement passes through the center hole of the CT, so azimuthal magnetic field around the power line induces EMF (ElectroMotive Force) on the coil inside the CT. This EMF is measured so the current on the power line is measured. This is the basic story of how CT works.
If the current frequency is low like 10 Hz, then I fully accept that CT really works. But I'm now confused at a high-frequency operation. The current is the source of the magnetic field and when the current oscillates, there is not only the magnetic field but also the electric field. The combined field is what we call an EM (ElectroMagnetic) wave. My frequency is 13.56 MHz which is a rather high-frequency, so the power line should play as an EM wave emitting antenna. EM wave generated from the power line propagates to CT first. However, CT has a rather thick metal case (much thicker than the skin depth at this frequency) so EM wave will be reflected from it. It means the magnetic field as a part of the EM wave fails to reach inside the CT so CT should not work! I think the only way for CT to work is that the magnetic field alone pass through the metal so they get in touch with the coil. But..Is it really possible? The time-varying magnetic field can exist alone without the electric field?
Of course, a commercial CT works well even for higher frequency. Could you please give me some idea of breaking this confusion?
goodphy said:
Hello.
The magnetic field of the conductor surrounds it circumferentially, and will induce a voltage in another wire which lies parallel to the first. Your CT conductor is wrapped round the wire, and no EMF is induced in this direction. In the longitudinal direction it is like a short parallel wire but does not form a compete circuit, so no current can flow. As no current flows, there is no shielding effect.
Hello.
I'm sorry but I don't understand your geometry.
The circumferential magnetic field around the conductor will induce a voltage on another wire which is in parallel oto the first conductor? This EMF is very different than what I'm used to such as a solenoid coil so I don't get how EMF is induced on the latter wire.
Longitudinal direction? short parallel wire? could you provide me a simple drawing so I can get a clearer view?
Related to Can a time-varying magnetic field pass a metal sheet?
1. Can a time-varying magnetic field pass through a metal sheet?
Yes, a time-varying magnetic field can pass through a metal sheet. However, the extent to which it can pass through depends on the strength of the magnetic field and the properties of the metal sheet.
2. How does a time-varying magnetic field interact with a metal sheet?
A time-varying magnetic field creates an electric field within the metal sheet due to the movement of the electrons. This can induce a current within the metal sheet, which in turn creates its own magnetic field that opposes the external magnetic field.
3. Will the metal sheet experience any changes when a time-varying magnetic field passes through it?
Yes, the metal sheet will experience changes due to the induced current and resulting magnetic field. These changes can include heating of the metal sheet, changes in its magnetic properties, and potential deformation or damage.
4. Can a metal sheet block a time-varying magnetic field?
Yes, a metal sheet can block a time-varying magnetic field to some extent. The thicker and more conductive the metal sheet is, the more it will block the magnetic field. However, some of the magnetic field may still pass through any gaps or imperfections in the metal sheet.
5. What factors affect the ability of a metal sheet to block a time-varying magnetic field?
The ability of a metal sheet to block a time-varying magnetic field depends on its thickness, conductivity, and permeability. Thicker and more conductive sheets are better at blocking the magnetic field, while sheets with higher permeability can redirect the magnetic field around it.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
