Can a Triangle with Area 1 Have a Side Less Than √2?
  • MHB
  • Thread starter anemone
In summary, the Triangle Inequality Theorem states that the sum of any two sides of a triangle must be greater than the third side. It is used to determine if a set of given side lengths can form a valid triangle and to find the range of possible values for the third side. The Law of Cosines is derived from the Triangle Inequality Theorem and is a more general form of the theorem. The formula for finding the area of a triangle is A = 1/2 * base * height, and the Triangle Inequality Theorem is essential for determining the validity of a triangle, which is necessary for finding its area.
anemone
MHB
POTW Director
3,883
115
Let $p,\,q,\,r$ be the sides of triangle $PQR$ with $p\ge q\ge r$. Prove that if the area of triangle $PQR$ is 1, then $q\ge \sqrt{2}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to greg1313 for his correct solution. :)
Here is the step-by-step solution:
We're given that the area of the triangle $PQR$ is 1, so we have
$\dfrac{pq\sin R}{2}=1\,\,\,\implies\,\,\sin R=\dfrac{2}{pq}$
By using the trigonometric identity that says $\sin^2 R+\cos^2 R=1$, we then have
$\cos R=\dfrac{\sqrt{p^2q^2-4}}{pq}$---(1)
By the Law of Cosines we have
$\begin{align*}r^2&=p^2+q^2-2pq\cos R\\&=p^2+q^2-2pq\left(\dfrac{\sqrt{p^2q^2-4}}{pq}\right)---(\text{from (1)})\\&=p^2+q^2-2\sqrt{p^2q^2-4}\end{align*}$
Since $q\ge r$, $q^2\ge r^2$ so we have
$q^2\ge p^2+q^2-2\sqrt{p^2q^2-4}$
$2\sqrt{p^2q^2-4}\ge p^2$
$4p^2q^2-16\ge p^4$
$0\ge p^4-4p^2q^2+16=(p^2-2q^2)^2+16-4q^4$
In order for the above inequality to be true, $16-4q^4$ cannot be positive, therefore
$16-4q^4\le 0$
$q\ge \sqrt{2}$ (Q.E.D.)
FAQ: Can a Triangle with Area 1 Have a Side Less Than √2?
What is the Triangle Inequality Theorem?
The Triangle Inequality Theorem states that the sum of any two sides of a triangle must be greater than the third side. In other words, if a, b, and c are the lengths of the sides of a triangle, then a + b > c, a + c > b, and b + c > a.
How is the Triangle Inequality Theorem used to solve problems?
The Triangle Inequality Theorem is used to determine if a set of given side lengths can form a valid triangle. It can also be used to find the range of possible values for the third side of a triangle, given the lengths of the other two sides.
What is the relationship between the Triangle Inequality Theorem and the Law of Cosines?
The Law of Cosines is derived from the Triangle Inequality Theorem. It is a more general form of the theorem and can be used to find the lengths of sides and measures of angles in any triangle, not just right triangles.
What is the formula for finding the area of a triangle?
The formula for finding the area of a triangle is A = 1/2 * base * height, where A represents the area, base represents the length of the triangle's base, and height represents the perpendicular distance from the base to the opposite vertex.
How is the Triangle Inequality Theorem related to the area of a triangle?
The Triangle Inequality Theorem is essential for determining the validity of a triangle, which is necessary for finding its area. If the given side lengths do not satisfy the Triangle Inequality Theorem, then the triangle does not exist, and the area cannot be calculated.
