Can all continuous functions be differentiated?
In summary, continuous functions can be differentiated as long as they meet certain criteria. These criteria include being defined on an open interval, having a finite limit at each point, and being continuous at every point on the interval. However, not all continuous functions can be differentiated, as there are some functions that are not defined on open intervals or do not have a finite limit at each point. Additionally, some functions may be continuous at every point but still not be differentiable. Overall, while many continuous functions can be differentiated, there are some exceptions to this rule.
phizics09
38
Can anyone give me an example of a continuous function that is NOT differentiable(other than the square root function)? I have to prove that not all continuous functions are differentiable.
Thanks!
Thanks!
In what sense do you mean that the square root function is not differentiable?
Some functions to consider are:
|x -1|
|cos(x)|
x2/3
the "standard" example is f(x) = |x|.
the function SammyS no doubt intended was:
$f(x) = \sqrt[3]{x^2}$, as $f(x) = x^{\frac{2}{3}}$ is undefined for real x < 0.
Now, the natural question that you should ask yourself is:
Is there continuous nowhere differentiable functions?
I don't think so :S Is there?
in fact, "most" functions aren't differentiable, in the sense that the "bad" ones vastly out-number the "good" ones. this may come as a surprise to you. your teachers have been sheltering you from this terrible truth, and only letting you play with the "nice" functions.
oh haha thanks guys! :)
$\displaystyle g(x)=\left(\,\sqrt[3]{x}\,\right)$ is defined for all x, when considered as a real function.
So $\large{ f(x)=x^{\frac{2}{3}}}$ is also defined for all real x
i understand what you're saying, every real number has a cube root. for reasons that are probably too far off-topic for this thread, some authors do not define $a^q$, when a < 0, and q is rational. it can be done for odd denominators, if one is careful. but some treat it as "complex-valued" (mathematica does this, i believe). there's a certain ambiguity in what the symbols mean.
when i learned calculus the first time, $\sqrt[3]{x}$ was a perfectly good function, defined on all of $\mathbb{R}$. things change once you consider the reals in terms of the complex field.
FAQ: Can all continuous functions be differentiated?
What is continuity and why is it important in mathematics?
Continuity is a fundamental concept in mathematics that describes the smoothness and unbrokenness of a function. It is important because it allows us to define and analyze functions in a precise and rigorous manner.
How do you determine if a function is continuous at a specific point?
A function is continuous at a specific point if the limit of the function exists at that point and is equal to the value of the function at that point. This means that the function does not have any sudden breaks or jumps at that point.
What is the difference between a removable and non-removable discontinuity?
A removable discontinuity is a point where a function is not continuous, but it can be made continuous by redefining the function at that point. A non-removable discontinuity is a point where a function is not continuous and cannot be made continuous by redefining the function.
What is the definition of a derivative?
The derivative of a function at a specific point is the rate of change of the function at that point. It represents the slope of the tangent line to the graph of the function at that point.
How do you calculate the derivative of a function?
To calculate the derivative of a function, you can use the limit definition of a derivative, which involves finding the limit of the slope of a secant line as the two points on the line get closer and closer together. Alternatively, you can use differentiation rules, which are shortcuts for finding the derivative of common functions.
