Can an electron in the 1s orbital be indefinitely far from the nucleus?
In summary: The electron exists as a probability distribution, not as a physical object with a definite location. Therefore, asking where it is at any given moment is not a meaningful question.
  • #36
PeterDonis said:
I don't think the OP is doing that since he has already agreed, in the post that you quoted, that changing the zero point of potential energy does not change anything in his calculations.
Yes I had another look at his post and I see what you mean. It seems that he forgot to take into account the fact that during a transition to the ground state the ionisation energy is radiated to the surroundings.
  • #37
Stephen Tashi said:
If we detected an electron on the moon, how would we know which atom it "belonged to"? Does answering the question in OP require setting up a situation where we somehow know we are detecting an electron that belongs to the the atom in question and not to an atom that's part of the moon?
I think a good reply to your question has been given by ZapperZ in post 17.
  • #38
And that, in the reverse process, you have to add that energy back, yes.
  • #39
Post #17 contrasts emprical facts with theoretical probabilities. How does this answer the question of determining which atom an electron "belongs to". Are we saying that, empirically, a detected electron can be assigned to one particular atom?
  • #40
I don't think this is the case in general. In some particular situations it might be, for example, if we have a single atom confined in a trap. But nobody is going to build a single-atom trap the size of the Earth-Moon distance.
  • #41
Dadface said:
Does that mean if you have measured where it is, it's meaningful to ask where it is?
That is to some extent interpretation dependent. From the formalism Peter is of course correct. But let's take say Consistent History's (CH) interpretation. It says if you measure it then it has that position. But after the measurement its wavefunction will then start to spread. Again the formalism is silent on it's position, but the CH interpretation says it has a position somewhere between the areas of the wavefunction that are not zero. Over time my view of QM has changed quite a bit and my view now is like Peters - but interpretations have various takes on the issue. It's part of the reason Wienberg doesn't really like any interpretation. Maybe we just have to accept reality is just a mathematical description, and that's all you can really say, especially in areas beyond our direct experience from which our everyday view of the world is formed. As quantum effects leak into that world because of advancing technology expect to see some really weird things eg a well known one is the behaviour of liquid Helium.
Thanks
Bill
  • #42
While this is true, if we are going to go down that rabbit hole, it should be in a separate thread in the interpretations forum. :wink:
For this thread and this forum, "the formalism" is what we should use.
Likes bhobba
  • #43
jaumzaum said:
The situation I was describing was a bound electron in the position x=R going to the position x=4R by itself, while still bounded to the atom and in the 1s orbital with that characteristic energy of -13,6eV, no external work being made. This is possible by my understanding right? At least it seems to be possible by Schrodinger equations if I'm not misunderstanding it.
You are misunderstanding it. The Schrodinger equation gives us the probability of finding the electron at a given position, but that doesn't imply that that it "goes to" that position from somewhere else - not even if we had previously measured the position and gotten a different result.
Let's say that we measure the position at time ##T_1## and find the electron at ##x=R##. Terrific... we can say that electron was at that position at the time of the measurement. But what about a moment later? We don't have a position measurement from a moment later so we cannot say that the electron is still at that position a moment later - no measurement, no position. Instead we use the Schrodinger equation to calculate the wave function of an electron at time ##t=T_1+\Delta{t}## given that it was at ##x=R## at time ##T_1##; we'll get a probability distribution that says it's likely to be fairly close to ##R## but continues to spread out over time.
So we measure it again, at time ##T_2##, and this time we find it at ##x=4R##. That doesn't mean that it moved from ##x=R## to ##x=4R## during the time interval between ##T_1## and ##T_2##; that interpretation would imply that it had a definite position between measurements, and it doesn't. Instead, the first measurement took the electron from the state "no definite position" to the state "at position ##R## at time ##T_1##"; and the second measurement took it from the state "no definite position" to the state "at position ##4R## at time ##T_2##". Both measurements necessarily changed the energy of the electron (although the total energy of the system including the measuring device is conserved).
Likes Vanadium 50, PeterDonis and bhobba
  • #44
PeroK said:
This does not make sense in QM. If the electron is in a bound state it has no well-defined position. It cannot "go from A to B"; it cannot "be at A" and it cannot "move to B".
None of these classical descriptions make any sense in terms of the SDE, which describes the wavefunction.
An energy eigenstate describes a static configuration, i.e., nothing moves at all. It also implies that only conserved quantities, whose representing self-adjoint operators commute with the Hamiltonian, can have determined values. All others (among them position and momentum in the case of interacting particles) are indetermined and you can only give probabilities for finding a certain possible value when measuring one of these observables (Born's rule).
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
