A Can an Oscillating Eternal Universe be Described without Singularity?
victorvmotti
Consider the FLRW metric.
We pick a specific definition for the scale factor as suggested bellow.
Suppose we have a hypothetical metric having the scale factor defined by
## a(t)=\sin(t) (1+ \text {sgn}(\sin(t)) +\epsilon ##
Does this make sense, mathematically (and physically)?
Like having a continuous smooth (differentiable) manifold. Or relating to the geometric properties of homogeneity and isotropy, an expanding and contracting universe?
Can this describe an oscillating eternal infinite universe without singularity?
If it does not, how to write a metric that can do so?
Just giving a scale factor doesn't tell us what the metric is. You need to write down the entire line element.
Actually, I meant that the Standard Model of cosmology and its metric to be used, only that we pick a specific definition for the scale factor as suggested.
The Standard Model of cosmology already includes a definition for the scale factor, which is not yours.
If you mean the general FRW metric, you should be able to write it down. And you should also be able to plug your ansatz for the scale factor into the equations that that metric gives (the Friedmann Equations) to see whether they make sense. Anyone with the background knowledge for an "A" level thread on this topic should be able to do that.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
