Can Any Genius Answer My Questions .can Any Body.
In summary, the conversation discusses the flickering of stars and the amount of photons that enter the eye when observing a star of first apparent visual magnitude. It also calculates the number of carbon atoms released when burning petrol and natural gas to produce the same amount of energy, and discusses the environmental impact of using these fuels. The reason for star flickering is attributed to atmospheric disturbances and refraction in the atmosphere.
mohdfasieh
QUESTION:
1: Stars are known to flicker.Estimate the number of photons entering the eye of an observer when he looks at the star of first apparent visual magnitude.Such a star produces flux on the surface of the Earth of 10(exp)-6
lumens/m(exp)2. One lumen is 0.00a6 watts.Why do stars flicker ?not the plannets.
2:Calculate the number of carbon atoms released on burning petrol (octane) and natural gas (methane) to produce the same amount of energy of one joule.1 kg of petrol produces about 44 x 10(exp)6 of energy wheras 1 kg of natural gas would release 55 x 10(exp)6 Joules.What is the ratio?From the point of view of preserving environment,which is better to use?
The pupil has a diameter of about 7 mm on a very dark night, so its collecting area is about 49 square millimeters. All you need to do to solve (1) is to perform a division.
All you need to do to solve (2) is to do a division.
Please show your work if you'd like additional help.
- Warren
You won't be needing a genius to solve these.
1. As chroot has said, you have the power/area. You know the area of your pupil, area times power/area = power. Convert lumens into watts.
You'll need to know the frequency of the photons. E = nhf where n is the number of photons, h is Planck's constatn, and f is frequency. Stars flicker purely due to atmospheric disturbances. It is more apparent for stars since they tend to be more faint. You don't see the sun flicker now you do ;)
"Why do stars flicker ?not the plannets."
Refraction in the atmosphere. Actually planets can flicker too if you have very turbulent air, say in a hurricane. Planets though are a lot bigger (in terms of intensity per surface area of photons that you recieve) so the molecules in the atmosphere cannot distort the full image as easily. Incidentally the stars can sometimes look like theyre changing color as well as flickering, again an optical property of the atmosphere.
FAQ: Can Any Genius Answer My Questions .can Any Body.
1. Can you define what a genius is?
A genius is typically described as someone with exceptional intelligence, creativity, and problem-solving abilities. However, the definition of a genius can vary and is often subjective.
2. Is it possible for anyone to become a genius?
While genetics may play a role in intelligence, studies have shown that hard work, dedication, and practice can also contribute to an individual's intelligence and abilities. So, while not everyone may become a genius, anyone can improve their skills and knowledge through effort and determination.
3. How can I determine if I am a genius?
The term "genius" is often used loosely and can be difficult to measure. Many standardized tests, such as IQ tests, can provide an indication of intelligence, but they do not necessarily determine if someone is a genius. It is important to remember that intelligence comes in many forms and cannot be solely measured by a test.
4. Are there different types of geniuses?
Yes, there are different types of geniuses, such as mathematical geniuses, artistic geniuses, and linguistic geniuses, to name a few. Each type of genius excels in a specific area and may have unique abilities and thought processes.
5. Can a genius answer any question?
A genius may have a higher level of intelligence and problem-solving abilities, but they are still limited by their knowledge and experience. It is possible that a genius may not know the answer to every question, but they may have the skills to find the answer or come up with a solution.
