Can anybody explain this to me? (Analysis)
In summary: Thanks so much for your help! I was having a hard time understanding that solution. Your explanation makes a lot more sense.
Artusartos
247
For x in [0, infinity), let [itex]f_n(x)= \frac{x}{n}[/itex]...
Determine whether [itex]f_n[/itex] converges uniformly to f (the limit, which is equal to 0) on [0,1].
Answer:
Let [itex]\epsilon > 0[/itex] be given. Let [itex]N= \frac{1}{\epsilon} [/itex]. Then for n>N, [itex] | f_n(x) - 0 | = | \frac{x}{n} | \leq \frac{1/ \epsilon}{n} = \frac{1}{n \epsilon} < \epsilon[/itex] as desired.
My questions:
1) Why is [itex]| \frac{x}{n} | \leq \frac{1/ \epsilon}{n} [/itex]? How do we know that x is less than 1 over epsilon?
2) Why is [itex] \frac{1}{n \epsilon} < \epsilon[/itex]?
3) Finally, how did they know that N was supposed to be 1/epsilon?
Thanks in advance
This "proof" is false.This sequence does not converge uniformly in that interval,because the suprimum for x is not final so certainly does not converge to 0.
But this answer is from here (page 49, exercise 24.2 b)
http://www.scribd.com/doc/70434268/Ross-Solutions
I don't know what you mean by "not final". Since the sequence converges, it MUST converge uniformly on any closed and bounded (i.e. compact) interval.
(I assume you mean page 47.) The proof for part (b) says "Claim: [itex]f_n \rightarrow f[/itex] uniformly on [0,1]." Part (c) shows by contradiction that it is not true on [itex][0,\infty)[/itex].
I am not sure which part you are trying to solve:
I was actually talking about part (b)...about why it converges uniformly on [0,1].
Oops! I misread the problem.
I read through the proof at your link, and it's a mess. My comments below:
Answer:
My questions:
In general, it's not true. All you know is that [itex]0 \leq x \leq 1[/itex]. If [itex]0 < \epsilon < 1[/itex] (assumption not stated in the proof), then [itex]x \leq 1 < 1/\epsilon[/itex].
This is certainly not true. Take [itex]\epsilon = 1/10[/itex], [itex]N = 10[/itex], and [itex]n = 11[/itex]. Then
[tex]\frac{1}{n \epsilon} = \frac{1}{11 /10} = \frac{10}{11}[/tex]
which is certainly not less than 1/10.
I suggest ignoring that "solution" altogether. The statement is true, but the proof is bogus.
I suggest starting with
[tex]|f(x) - 0| = \left|\frac{x}{n}\right| \leq \left|\frac{1}{n}\right| \ldots[/tex]
where the inequality is true because [itex]|x| \leq 1[/itex].
So can I prove it like this?
[itex] | f_n(x) - 0| = | \frac{x}{n} | \leq \frac{1}{n} [/itex]
So when is 1/n equal to epsilon? It is when n=1/epsilon...so n needs to be greater than 1/epsilon. Do you think my answer is correct?
Yes, if [itex]n > 1/\epsilon[/itex], then [itex]1/n < \epsilon[/itex], which is what you need. The key is that this choice of [itex]n[/itex] works for any [itex]x \in [0,1][/itex].
Thanks a lot. I also have another question, if you don't mind...
From the same link that I gave...for exercise 24.6 (b), we are asked if f_n converges uniformly on [0,1]. And the solution (in the link) says that [itex] | \frac{1-2xn}{n^2} | \leq \frac{1}{\sqrt{n}} [/itex]. I wasn't able to understand why that is true...
That's because it is false. Consider [itex]x = 1[/itex], [itex]n = 2[/itex]. Then
[tex]\left|\frac{1 - 2xn}{n^2}\right| = \left|\frac{1-4}{4}\right| = \frac{3}{4}[/tex]
which is not less than [itex]1/\sqrt{2} \approx 0.7071[/itex].
Whoever wrote the solution manual you are using is just plain wrong.
You can obtain a bound that will work as follows:
[tex]|1 - 2xn| \leq |1| + |2xn| = 1 + 2n|x| \leq 1 + 2n \leq n + 2n = 3n[/tex]
Try using this to solve the problem. You'll have to use a different N from what the solution chose, but it should work.
Thanks a lot :)
FAQ: Can anybody explain this to me? (Analysis)
What is analysis?
Analysis is the process of breaking down a complex topic or problem into smaller, more manageable parts in order to gain a better understanding of it. It involves examining the underlying components, relationships, and patterns in order to draw meaningful conclusions.
Why is analysis important?
Analysis is important because it allows us to make sense of complex information and make informed decisions. By breaking down a topic or problem into smaller parts, we are able to gain a deeper understanding of its overall structure and identify key factors that may be influencing it. This can help us to solve problems, make predictions, and improve processes.
What are the different types of analysis?
There are various types of analysis, including quantitative analysis, qualitative analysis, and comparative analysis. Quantitative analysis involves using numerical data and statistical methods to interpret and draw conclusions. Qualitative analysis involves examining non-numerical data, such as text, images, or videos, to gain insight and understanding. Comparative analysis involves comparing and contrasting different data sets or variables in order to identify patterns or relationships.
How is analysis conducted?
Analysis can be conducted in a variety of ways, depending on the type of data and the purpose of the analysis. Generally, it involves collecting and organizing data, identifying patterns and relationships, and interpreting the data to draw conclusions. This can be done through various techniques such as statistical analysis, content analysis, or visual analysis.
What are the benefits of analysis?
The benefits of analysis include gaining a deeper understanding of complex topics, identifying key factors and patterns, making informed decisions, and improving processes or systems. It can also help to identify potential problems or areas for improvement, and provide evidence to support arguments or recommendations. Additionally, analysis can lead to new discoveries and insights that may have practical applications.
