Can anyone access supercompute time?
  • Thread starter aheight
  • Tags
    Time
In summary, if you do not have access to a supercomputer through some project, you would have to pay to access a large machine. Most supercomputers are just large numbers of computers similar to the computer you own. So unless you can parallelize your problem so it can run on many cores at the same time, it will not run any faster on a supercomputer. Do you know how to parallelize your problem?
aheight
321
109
TL;DR Summary
What does it take for someone not affiliated with academia to get time on a supercomputer?
I'm working on a problem which can be CPU-intensive and was wondering what it would take for me to get time on a supercomputer to run it and if so, how would the speed of a typical supercomputer compare to my 4.5 GHz machine? It's a relatively simple Mathematica program to find polynomial roots.
Thanks for reading guys.
Computer science news on Phys.org
Basically, if you don't have access to a supercomputer through some project, you would have to pay to access a large machine. Most supercomputers are just large numbers of computers similar to the computer you own. So unless you can parallelize your problem so it can run on many cores at the same time, it will not run any faster on a supercomputer. Do you know how to parallelize your problem?
Likes aheight and FactChecker
Thanks for that. It's surprising to me. I thought supercomputers run a lot faster. I can easily parallelize it via ParallelTable in Mathematica for multiple runs but I can't parallelize it for a single run of Newton Iteration of a single root. .
The good news is that anyone (pretty much) can submit a proposal to run on various government-owned supercomputers. The bad news is that your proposal will not be successful.
  1. The proposal needs to advance the mission of the agency owning the supercomputer. DOE's NERSC? Needs to be related to Department of Energy research. OLCF? Either that or needs to advance supercomputing somehow.
  2. The proposal process is heavily oversubscribed. Perhaps 3x as much time as requested as is able to be awarded.
  3. Your program has to be very parallel. My record is over 3 million simultaneous processes.
  4. The architectures for the largest machines don't run Mathematica. Furthermore, because desire to use these machines is so intense, an enormous premium is placed on efficiency. That usually means running code you control, not code Wolfram controls.
  5. Time is given out in chunks of millions of CPU hours. Your project sounds too small.
However, you do have an option: commercial clouds. Mathematica can use Amazon's EC2. Cost varies by time of use, the amount of memory you need, the number of CPU cores, etc. You will end up in the ballpark of tens of cents per hour used: i.e. if you had ten computers working for a day, expect a bill of $20-100.
Likes lomidrevo, berkeman and aheight
Thanks. I googled it. Would you happen to know if the performance would be much better than my machine? For example, if a (non-parallelized) Newton Iteration on my 4.5 GHz machine took 450 sec, how much faster would it run on the EC2?
Can I benchmark code I don't have and even if I had it, I would have to pay to benchmark it? Um...no.
EC2 has a dozen different types of processors and of order two-dozen variations on memory and effective CPU count. There is no single number. There's real work involved, and frankly, you need to be the person doing it.
The CPU cores are 8175M's. You should be able to figure out the relative performance. However, as the clock is slower, it will likely emerge that it takes somewhat longer.
But let's step back and look at the big picture. You have a job that takes ten minutes to run. Running it on a supercomputer where it sits in the queue for a week and then runs in one minute - how does this help you? Even if it sits in the queue for only an hour. How does this help?
Likes lomidrevo and aheight
Vanadium 50 said:
But let's step back and look at the big picture. You have a job that takes ten minutes to run. Running it on a supercomputer where it sits in the queue for a week and the runs in one minute - how does this help you? Even if it sits in the queue for only an hour. How does this help?
Ok I get it now. Was just considering alternatives. My work is not mission-critical. Thanks for helping!
FAQ: Can anyone access supercompute time?
What is supercompute time and why is it important?
Supercompute time refers to the access and use of high-performance computing resources for scientific research and data analysis. These resources are crucial for solving complex problems and processing large amounts of data in a timely manner.
Who can access supercompute time?
Supercompute time is typically available to researchers and scientists from academic institutions, government agencies, and private companies. However, the eligibility criteria and application process may vary depending on the specific supercomputing center or facility.
How do I apply for supercompute time?
The application process for supercompute time varies depending on the supercomputing center or facility. In general, applicants are required to submit a proposal outlining their research objectives, data requirements, and expected computing resources. The proposal is then reviewed by a committee, and if approved, the applicant is granted access to supercompute time.
Is there a cost for accessing supercompute time?
Some supercomputing centers may charge a fee for the use of their resources, while others may offer free access to academic researchers. Government agencies and private companies may also have to pay for supercompute time. It is important to check with the specific supercomputing center for their pricing and payment policies.
How much supercompute time can I access?
The amount of supercompute time allocated to an individual or research group depends on various factors, such as the complexity of the research project, the availability of resources, and the number of applications received. Supercomputing centers typically have a limit on the amount of time that can be allocated to a single project or user.
