Can arXiv papers be considered as reliable sources of information?
In summary, the conversation discusses the credibility of papers uploaded on arXiv and whether they should be taken as seriously as journal published papers. While arXiv does not have a formal peer review process, it is generally assumed that authors eventually try to get their work published in a journal. However, papers that have been on arXiv for a long time and have not been accepted by any journals should be approached with caution. The possibility of referees coming to a correct decision or the authors making multiple attempts to get published are both factors to consider when evaluating these papers. Ultimately, it is important to have a certain level of skepticism towards all papers, regardless of where they are published.
Dadface
2,489
105
Is it correct to assume that, in general, authors who have papers accepted by arXiv eventually try to get their work published in a journal? If so what should we make of arXiv papers which apparently do not get accepted by any journals? Should we take those papers as seriously as we would take a journal published paper?
As an example, this morning I was scanning through an active thread on the quantum physics forum of PF and reference was made to an arXiv paper from 2005. I couldn't help wondering if the author(s) of this paper were content to just leave it in arXiv or whether they actively tried to get it published elsewhere and failed in their attempts. If the latter is the case it seems to be possible that the referees,who are supposed to be experts, did not agree with the findings of the work. What then should we make of the work?
In general, but not as a general rule. For example, people will also put thing such as lecture notes and PhD theses on the arXiv. These are typically not published in peer reviewed journals.
In general no. You would need to have enough knowledge in the particular field in order to judge the paper. Also note that being peer reviewed is not equivalent to being correct. It just means that the authors managed to convince one or more reviewers to accept the paper.
Likes blue_leaf77 and BvU
It is important to realize that the arXiv does not really "accept" anything; anyone with a valid e-mail address (e.g. someone@someuniversity.edu) can upload a manuscript to the arXia and all that might happen is that someone takes a very quick look at it (I doubt they have time to do more than to read the title and abstract) to make sure it is not obviously nonsense before it becomes available (which is why it takes less than 24 hours before a manuscript that has been uploaded becomes available). The manuscript is never really reviewed as such.
The most common reason by far for getting paper rejected it is that it deemed not suitable or important enough for a journal. It is actually quite rare for referees to claim that something in the manuscript is flat-out wrong. Writing a paper takes a lot of time and effort and you will only submit it once you have convinced yourself and your collaborators that what you have done is correct. This does not mean that all submitted papers are free of errors (far from it), but it does mean that it the errors tend to be less than obvious and the referees are unlikely to spot it; at least in papers from well-known groups.
Once you have worked in a field for a few years you get to know most of the players, and if one of those uploads something to the arXiv I will usually assume that what is in there is correct and will eventually be published (and I might not even bother looking up the published version). This does not necessarily mean that I believe that they've reached the right conclusion, I can still e.g. disagree with their initial assumptions or believe hat they missed something important.
Likes BvU
Definitely not. Such papers have not undergone peer review. That doesn't mean that they are wrong, but they are definitely less credible.
Thanks for your replies everyone. Personally I don't know what to make of those papers that have been with arXiv for several years. It's easy to imagine that the authors have made several approaches to journals and have been turned down by the referees each time. Just one possibility is that the referees have come to a correct decision.
I would agree that this is a possibility among many. Unless you know (professionally - not that they are your friends) the authors are reliable, it is probably good to have a larger portion of scepticism (although you should always have some portion of scepticism).
Likes Dale and Dadface
I've seen the reviewer side of the peer review system too many times to place too much trust in it. In addition to having editors publish papers over my objections as a reviewer, colleagues and I have also had editors refuse to publish our comments pointing out obvious flaws after mistakes make it into print.
For the most part, there is no simple way to determine the quality of a paper from the venue in which it appears. Usually I develop a sense for which authors are careful and which are careless. But I never recommend not bringing your critical thinking skills.
One of my first significant contributions to Dan Kleppner's program at MIT was finding a significant mistake in a Phys Rev Letter that they had published a few years before. The authors, the peer-reviewers, and most of the readers for several years after the paper was published all missed the error.
No. but they usually are well thought out proposals that are more digestible than Youtube videos and Facebook memes.
The pros and cons of peer review won't be settled here. However, I think that anyone asking that peer-reviewed papers be error-free is being unrealistic. (One could even argue that by removing the obvious errors, peer-review ensures that remaining errors are subtle and more difficult to find). However, I think the ensemble of peer-reviewed papers is more reliable than the ensemble of all papers, peer-reviewed or not.
There are reasons for not publishing a preprint. I've done it. I had a paper in review hell until it was no longer timely. But it was on the arXiv and everyone who needed to see it has seen it. But this is an exception. Most of the time, papers that never move beyond the arXiv shouldn't.
Likes DrClaude and BvU
Related to Can arXiv papers be considered as reliable sources of information?
1. Are arXiv papers peer-reviewed?
No, arXiv papers are not peer-reviewed. This means that they have not undergone a formal evaluation process by experts in the field. However, they are often read and commented on by other researchers, which can still provide a level of quality control.
2. Can I trust the information presented in arXiv papers?
While arXiv papers are not peer-reviewed, they are often written by qualified and reputable scientists. Additionally, the platform has a system in place to flag papers that may contain errors or questionable content. However, it is always important to critically evaluate the information presented in any source, including arXiv papers.
3. Are arXiv papers considered credible sources for academic writing?
It depends on the specific guidelines of the academic institution or publication. Some may consider arXiv papers as credible sources, while others may not. It is important to check with the specific guidelines or ask a professor or editor for clarification.
4. Can I cite arXiv papers in my research?
Again, this may depend on the guidelines of the academic institution or publication. Some may allow citing arXiv papers, while others may require peer-reviewed sources. It is best to check with the specific guidelines or ask a professor or editor for guidance.
5. Are arXiv papers considered primary sources?
No, arXiv papers are not considered primary sources. They are considered preprints, meaning they have not yet been formally published in a journal or conference proceeding. However, they may still be valuable sources of information for research purposes.
  • General Discussion
  • STEM Academic Advising
  • Beyond the Standard Models
17K
  • STEM Career Guidance
