Can better sensors extract more info from old lens w/o limits?
In summary, the conversation discusses the relationship between a new high-resolution camera sensor and the need for new lenses. Some argue that the sensor will utilize the full potential of any lens, while others believe there is a limit to the amount of information a lens can provide. The concept of the "quantum Zeno effect" is brought up in relation to this topic. Additionally, the use of Fourier transforms and modulation transfer functions is discussed as a way to measure resolution and contrast. Ultimately, the conversation centers around the idea that the performance of a camera system is determined by both the lens and the sensor.
nugat
This problem I encountered in my photography forum.
A new model of camera comes out with a much higher megapixel sensor (Nikon D800, 36mpix). I argue that such sensor will need new lenses to be meaningful. Others claim that a given lens performance (here resolution) is always utilized by a new higher resolution sensor. They call up Fourier transforms, modulation transfer functions etc. I am not an engineer, more of an amateur philosopher. To me it smells of Zeno paradox (a "quantum Zeno effect" ?). There sure must be a limit on the amount of information a new ever improving recording medium (sensor) can extract from the same old lens? Or not?
A summary of the original opponent position below:
"... As I wrote the formula is an approximation. For accurate results one would need to multiply the MTFs by means of Fourier transforms.
Every image will show more resolution on the D800 with any lens at any aperture than on previous Nikon's.
The resolution of a system is a function of the resolution of it's parts, not only a single component.
The resolution of a lens plus sensor system can be approximated by:
1/Total resolution = 1/lens resolution + 1/sensor resolution. Or
Total resolution = (lens resolution)x(sensor resolution) / [ (lens resolution) + (sensor resolution) ]. "...
Or does this issue belong to classical physics?
I mean, in my mind I see a lemon running out of juice at some point of the squeeze.
Isn't the information coming through any given lens limited then? No more photons to be converted into electrons? On one hand it's the issue of quantum efficiency of the CMOS sensor, but also the physical information limit of the light field?
So are those Fourier transforms of MTFs accurate descriptions or we are at the point where technology stumbles on quanta?
Here is a bit more of the photo forum exchange:
MY POST
"Resolution figures are meaningless without accompanying contrast data.
One has to put somewhere the cutoff line: what is acceptable. In cinematography Zeiss Master Prime delivering 70lp/mm at 70% contrast is the standard bearer (at 25k U$ and several pounds)
In photography I am willing to accept 50% contrast as a minimum performance measure.
If somebody wants to go down to MTF 25 or even 10--his choice. He will be able to point to "extra resolution" on his cranked up monitor viewed at 100%.
The concept of a lens delivering an ever-increasing stream of visual information as the recording medium becomes more and more capable, is philosophically intriguing, to say the least. A "quantum Zeno effect" of sorts."
THE ANSWER:
"If you would have read the thread I linked to further, you would have found that the approximation is based on multiplications of MTFs by means of Fourier transforms, You can pick any frequency (resolution) you want. Higher frequencies are generally used as a measure of resolution and lower as contrast.
The approximate formula is still valid and serves as a good first approximation to explain the principles of what can be expected for a system of lens plus sensor.The optical performance of a system of two components (lens and sensor) is not determined just by a single component but by both."
You can think of it as two MTFs stacked on top of each others."
Related to Can better sensors extract more info from old lens w/o limits?
1. Can better sensors extract more information from old lenses without any limitations?
It is possible for better sensors to extract more information from old lenses, but there may be limitations depending on the specific lens and sensor combination. Factors such as lens compatibility, resolution, and image quality can all affect the amount of information that can be extracted.
2. How do better sensors improve the performance of old lenses?
Better sensors can improve the performance of old lenses by increasing the resolution and dynamic range of the images captured. This allows for more detailed and accurate information to be captured from the lens.
3. Are there any risks to using old lenses with better sensors?
There are some potential risks to using old lenses with better sensors. These include compatibility issues, reduced image quality, and potential damage to the lens or sensor if not used properly.
4. Is it worth investing in better sensors for old lenses?
Investing in better sensors for old lenses can be worth it if you are looking to improve the performance and image quality of your existing lenses. However, it may not be necessary if you are satisfied with the current performance of your lenses.
5. Can better sensors make up for the limitations of old lenses?
While better sensors can improve the performance of old lenses, they cannot completely make up for any inherent limitations of the lens. It is important to understand the capabilities and limitations of both the lens and sensor to achieve the best results.
  • Astronomy and Astrophysics
13K
