Picalilli
- 4
- TL;DR Summary
- If a situation can exist where photons can escape black hole gravity, would “dark star” not be a more adequate name?
Summary: If a situation can exist where photons can escape black hole gravity, would “dark star” not be a more adequate name?
It is commonly accepted that once there is enough material put together to create a sphere with a mass big enough to prevent light from escaping, that this object then becomes some kind of death trap from which nothing can ever escape any more. This is commonly referred to as a “black hole” and the thesis then is that even no photon can ever escape a “black hole”.
Is this always the case?
Let's perform the following “Gedankenexperiment”:
Let's have two identical stars(S1 and S2) with diameter d and each having a mass between 101% and 103% of critical mass to prevent light from escaping. Both S1 and S2 qualify as “black hole”. Two parallel lines(a1 and a2)are at distance b from each other. S1 has it's center of mass on a1 and the center of mass of S2 is on a2. S1 and S2 are at least 300 000 light-years apart. S1 and S2 are sent flying towards each other along a1 and a2 at a relative starting speed between 75 and 85 % of the speed of light. Distance b has to be chosen such that the centers of mass of S1 and S2 come at least at one point closer to each other than 2.5 d and never closer than 2d, no matter what shape or mix the matter of S1 and S2 ever evolve to. As S1 and S2 approach each other and they both are composed of plasma and are not solid, a tidal effect will set in and both S1 and S2 will change shape (The force of gravity is directly related to the amount of mass, but so is the force of inertia). Losing their spherical shape results in weakening the gravity force on the edge of the system. If weakening the force of gravity results in photons escaping, the thesis doesn't hold water and black hole gravity can be overpowered. (2019-10-30)
