Can both of these equations be right?
  • Thread starter Dorothy Weglend
In summary: One assumes the box does not move, while the other assumes the box moves. When she tries to use the acceleration of the box with respect to the car to find the relative speed, she realizes that both equations are needed.
Dorothy Weglend
247
In solving my physics problems, I often end up with two equations for the same thing, they both seem right to me, and yet, it seems, they both can't be right.
I thought I would ask about this here.
I'm solving a problem which involves a box in the front of a railroad car. There is initially no motion, then the car starts to accelerate. I am asked to find various things about the box at the point when it hits the back of the car.
I started by trying to find the acceleration of the box. I get that from the kinetic friction:
fk = ma, or umg = ma, so a = ug, where u is the coefficient of kinetic friction.
With respect to the railroad car, we have
a - A = ug - A, where A is the accleration of the railroad car. So far, so good, I think. Now this is where my problems start.
If the distance the box travels backwards in the railroad car is l, then the time it takes for the box to contact the back of the railroad car is the same as it takes the car to advance l, so
l = At^2/2, and t = sqrt(2l/A).
So the velocity of the box, relative to the car, should be
v = (ug - A)sqrt(2l/A)
Of course, you can also use v^2 = 2as to do the same thing. I tried that:
v^2 = 2l(ug - A), so v = sqrt(2l(ug-A))
As far as I can tell, these aren't equivalent expressions, mathematically, for the same quantities, but I think my reasoning is sound in both cases.
This happens to me ALL the time. Can someone help me figure out which one of these is right?
Thanks,
Dorothy
Yes. So far, so good!
What makes you think that? According to that line of reasoning, with respect to the tracks, the box doesn't move! (If the car moves back a distance l with respect to the train, but the train moves forward a distance l in the same time...)
so
This is the time it takes the train to move a distance l with respect to the tracks.
This is the relative speed after the train moves a distance l--not what you want.
This time, since you are using the acceleration of the box with respect to car, you are finding the relative speed after the box moves a distance l within the car. This is what you want.
No, they are not equivalent. Each one sneaks in a different assumption. If you want to know what's happening at the moment the box reaches the back of the car, then use the acceleration (and distance) with respect to the car!
Well, you are right. I was thinking that the box didn't move. But of course, there is friction, which must move the box, so the train could move considerably farther than l to get the box all the way to the back of the train. Sheesh...
Thank you, Doc Al. You have helped me so many times, you are just great. I really appreciate it. I hope someday I can help people just like you do.
Dorothy
FAQ: Can both of these equations be right?
Yes, it is possible for both equations to be right. However, this depends on the context and variables involved. It is important to carefully examine the equations and their assumptions before determining their validity.
How can we determine which equation is more accurate?
The accuracy of an equation can be determined by comparing its predictions with real-world data. In scientific experiments, it is important to collect and analyze data to determine which equation better explains the observed phenomenon.
What if the two equations contradict each other?
If the two equations contradict each other, it is likely that one of them is incorrect. In this case, further investigation and analysis is necessary to identify the error and determine the more accurate equation.
Are there any mathematical techniques to reconcile two conflicting equations?
Yes, there are mathematical techniques such as regression analysis and curve fitting that can help to reconcile two conflicting equations. These methods can help to identify the relationship between variables and determine the most accurate equation.
Can an equation be considered "right" or "wrong"?
An equation cannot be inherently right or wrong. Its accuracy depends on its ability to explain or predict a phenomenon in a given context. A more accurate equation may emerge as new data and evidence become available.
