MHB Can co-prime numbers raise to a power that is equal to 1 mod(n)?
  • Thread starter Thread starter Poirot1
    Challenge
The discussion focuses on proving that if a is co-prime to n, where n is the product of two co-prime integers x and y greater than 2, then \( a^{\frac{\phi(n)}{2}} \equiv 1 \mod(n) \). Participants explore the applicability of the Chinese Remainder Theorem (CRT) and clarify that the argument must hold for both x and y to satisfy the equivalence. By applying Euler's theorem, it is established that \( a^{\phi(n)} \equiv 1 \mod(n) \), leading to the conclusion that \( |a^{\frac{\phi(n)}{2}}| \equiv 1 \mod(n) \). A contradiction is reached by assuming \( a^{\frac{\phi(n)}{2}} \equiv -1 \mod(n) \), ultimately confirming the initial claim. The discussion effectively demonstrates the relationship between co-prime numbers and modular arithmetic.
Poirot1
Let n =xy be a positive integer where x,y>2 are co-prime. Show that if a is co-prime to n, then $a^{\frac{\phi(n)}{2}}=1$ mod(n)
Mathematics news on Phys.org
Re: co-prime challenge
$$a^{\frac{\varphi{(n)}}{2}} \equiv b \pmod{n} ~ ~ ~ ~ \iff ~ ~ ~ ~ a^{\frac{\varphi{(n)}}{2}} \equiv b \pmod{x} ~ ~ ~ ~ \iff ~ ~ ~ ~ a^{\varphi{(x)} \frac{\varphi{(y)}}{2}} \equiv b \pmod{x} ~ ~ ~ ~ \implies ~ ~ ~ ~ b = 1$$
Explanations and justifications below:Step 1: Apply the CRT, since $n = xy$.
Step 2: Definition of the totient function, and $\gcd{(x, y)} = 1$.
Step 3: Recall $\varphi{(y)}$ is even as $y > 2$. Use Euler's Theorem as $\gcd{(a, x)} = 1$.
It occurs to me I've been using the parity property of $\varphi$ an inordinate number of times in the past week ;)​
Your method is better than mine. But in step 1, wouldn't the CRT be applicable if n and x were co-prime? As it is, the -> direction is clear, but how do you get the <- drection in step 1?
Yes, that is a good point. What is missing is that the step has to follow for both $x$ and $y$ for the equivalence to be fully satisfied (the argument is valid for both factors, so it does hold). Good catch! I guess one could slip a WLOG in there somewhere..​
By euler's theorem, $a^{\phi(n)}=1$ mod (n). Since n>2, phi(n) is even so that
$a^{{\frac{\phi(n)}{2}}^2}=1$ mod(n)
Thus, $|a^{\frac{\phi(n)}{2}}|=1$ mod(n)
Towards a contradiction, assume $a^{\frac{\phi(n)}{2}}=-1$ mod(n)
-> $a^{\frac{\phi(x)\phi(y)}{2}}=-1$ mod(x) using the multiplicative property of phi and the fact that any multiple of n is a multiple of x also.
since y>2, phi(y) is even so we get:
$a^{{\phi(x)}^{\frac{\phi(y)}{2}}}=-1$ mod(x). But (a,x)=1 so euler's theorem gives $a^{\phi(x)}=1$ mod(x). Also x>2 so 1 is not congruent to -1 mod(x). Therefore a contradiction has been established.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
