Comp Sci Can console commands like cin, cout, getch, etc be used in windows apps?
  • Thread starter Thread starter Pipsqueakalchemist
Using console commands like cin and getch in Windows applications can lead to issues, particularly with blocking the event loop. These commands are designed for console applications and do not integrate well with event-driven GUI frameworks, causing problems when trying to exit loops. The discussion emphasizes that blocking I/O operations are generally incompatible with GUI applications, which are built to handle user input through graphical elements. It is suggested to focus on learning the fundamentals of Windows GUI programming to address these challenges effectively. Understanding the appropriate structure for GUI applications is essential for solving common programming problems.
Pipsqueakalchemist
can I used console commands in windows application?
C++, visual studio
So I started working in a windows application. But i started having issues with blocking the event loop when using while loops that i never encountered before when using while loops in console application.
My theory is that I used commands like getch or cin to exit the loop in the window application and that those commands work fine in console but not in windows and that's why I can't exit my while loops and my event loop is blocked
Is this the case because if it's not then I'm at a complete loss because I've never encountered these issues before when coding in console.
You kind of let your other thread with this question just hang there.
But to repeat some from that thread: as a rule of thumb you cannot in general expect that blocking I/O and event driven applications mix well. Waiting for user input using cin in GUI application seems particularly weird and pointless since the GUI is there to handle user input with framework elements like buttons and text fields/areas. Perhaps you can describe what kind of problem you are trying to solve and what makes you want to mix console and GUI functions?
It will probably also be a good idea you learn the basics of (Windows) GUI programming and how to structure such an application to solve "standard problems".
Likes Tom.G and Mark44
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
9K
