Can Daisy Chaining Torque Motors Increase Power Output?
  • Thread starter Thread starter ktoz
    Motors Torque
Daisy chaining multiple smaller torque motors to a single shaft can potentially provide the same power output as a larger motor, provided the drives are properly configured. It's important to program one drive with the motion profile and the others for torque following to ensure synchronization. Users are encouraged to consult with the drive manufacturer for specific implementation details. While the suggested motors may not be an exact match, the concept of using multiple motors is valid. This approach can be a viable solution for achieving desired power levels in compact designs.
ktoz
Hi
I recently discovered torque motors and think they would be perfect for a device I’m designing, except for the fact that the power I need isn’t available in the size I’m looking for.
I’m wondering if two or more smaller torque motors connected to the same shaft can provide the same power as a single larger one?
Thanks
Probably, yes.
Can you post a link to the motors you are considering.
I haven’t found a perfect fit, but these are in the ballpark size-wise: technotion.com
QTR-A-160 SERIES​
These are industrial motors, not hobby motors, so the drives (servo amplifiers) should have that capability. Program the motion profile into one drive, then program the other drive for torque following. You may need to consult with the drive manufacturer because there are some nonobvious details that are necessary to make this work.
Likes berkeman and ktoz
OK, thanks.
Those motors may not be exactly what I need, but the daisy chaining idea is conceptually sound?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
