amit016
- 8
Just want to amplify the difference of inputs.
... it is a simple, safe, and cheap, experiment - why not try it for yourself and see?amit016 said:Simon Bridge: No, that is the reason I am asking you people it is practically possible or not ?
No, differential op amps require a positive and negative power supply to function properly. Without a power supply, the op amp will not have the necessary voltage to perform its operations.
If a differential op amp is used without a power supply, it will not function at all. The op amp will not have any power to amplify the input signal and will not produce an output.
Yes, it is possible to use a single power supply for a differential op amp. However, this requires additional circuitry to create a virtual ground, which is necessary for the op amp to function properly.
A dual power supply allows for a wider range of input and output signals to be amplified by the op amp. It also provides better stability and allows for the op amp to operate at a higher voltage, resulting in a larger output signal.
Yes, differential op amps can be powered by different voltages as long as the voltage difference between the two supplies is within the specified range for the op amp. However, using significantly different power supply voltages can affect the performance of the op amp and should be carefully considered.
