Can Earth or any spherical object in space act as a particle collider?
In summary, Earth or any spherical object in space cannot function as a particle collider in the traditional sense. While these objects have gravitational fields that can influence particles, a particle collider requires precise control over particle acceleration and collision, which is achievable in specialized facilities like the Large Hadron Collider. Earth's atmosphere and gravitational interactions do not provide the necessary conditions for high-energy particle collisions needed for scientific experiments.
adhd_wonderer
This is most probably a dumb idea as I'm far from deep physics knowledge but I was thinking.
What if Earth is hot inside not because of the pressure and the radioactivity but because it's mass attracts particles (similarly to gravitational lensing) and they collide right in the Earth's center?
  • Skeptical
Likes PeroK
Why would they not collide with various parts of the Earth before getting anywhere near the center? You are positing some magical particles that can avoid all of the particles that make up the Earth, arrive at the center at the same time, and then collide with each other. Really?
Likes sophiecentaur, Vanadium 50, adhd_wonderer and 2 others
What is "gravitational lensing" in ths context? Some nontrivial part of the earths internal energy is residual heat from collisions due to its viotent accretion history, because of gravity. Wikipedia is good.
Likes sophiecentaur and adhd_wonderer
This is exact.y the kind of question that (even brilliant) Scientists are constantly asking themselves. The answer (as in this case) is always to do with the actual numbers involved in each specific case. The temperature of the Earth's surface is the result of an equilibrium between all the radiated energy and all the energy contributions, such as solar energy, internally generated nuclear energy and the energy of present and past accretion.
The same calculations are made about Neutron Stars to account for the fact they are intense sources of very high energy radiation (Xrays). Accretion, in that case, accounts for the vast amounts of radiated energy where internal energy is not so much.
A better question is how we know that the centre of the Earth is hot in any case. No one has drilled down there to find out!
In addition to all the factors mentioned above, take in account that as you get closer to the center of the Earth or other spherically symmetric body, the gravitational attraction toward the center diminishes and completely disappears at the center.
For a question like this the most important thing would be to show
1) there is a quantitative discrepancy between the measured temperature of the center of the earth and predictions based on known physics
2) that this new physics makes a quantitative prediction of the right amount to resolve the discrepancy
The big issue I see here is that the known physics has a lot of variability. We don’t know the initial conditions with high precision. We also don’t have direct measurements of the core temperature.
When you have a lot of uncertainty on both the theoretical and the experimental side then it becomes difficult to claim that there is even any discrepancy to resolve, or which direction any new physics would need to go to resolve it. Maybe the new physics needs to be a mechanism to take heat away, not add it.
I guess the point is, before looking for a fix, the first thing is to find something that needs fixing. If it ain’t broke, don’t fix it. And “broke” and “fix” are both about quantitative measurements in science.
FAQ: Can Earth or any spherical object in space act as a particle collider?
Can Earth act as a particle collider?
Earth itself cannot act as a particle collider in the same way that man-made particle colliders like the Large Hadron Collider (LHC) do. However, high-energy cosmic rays constantly bombard Earth, and when they interact with the atmosphere, they can produce particle collisions that scientists study using ground-based detectors.
Are there natural particle collisions in space?
Yes, natural particle collisions occur frequently in space. High-energy cosmic rays, which are particles accelerated to near-light speeds by astrophysical processes, collide with interstellar matter, planetary atmospheres, and other particles in space, creating secondary particles and radiation that can be studied by space-based and ground-based observatories.
How do cosmic rays interact with Earth's atmosphere?
When cosmic rays enter Earth's atmosphere, they collide with atmospheric molecules, primarily nitrogen and oxygen. These collisions produce a cascade of secondary particles, known as air showers, which can include pions, muons, electrons, and neutrinos. These secondary particles can be detected by instruments on the ground, providing valuable data for scientific research.
Can other spherical objects in space, like planets or stars, act as particle colliders?
Similar to Earth, other spherical objects in space, such as planets and stars, can experience natural particle collisions due to cosmic rays. These collisions can produce secondary particles and radiation. For example, the Sun emits solar energetic particles that can interact with planetary atmospheres and magnetic fields, leading to particle collisions that can be observed and studied.
What scientific insights can be gained from studying natural particle collisions in space?
Studying natural particle collisions in space can provide insights into fundamental physics, such as the properties of cosmic rays, the behavior of particles at high energies, and the mechanisms of particle acceleration. Additionally, it can help us understand astrophysical phenomena, such as supernovae, black holes, and the interstellar medium, as well as improve our knowledge of space weather and its impact on Earth.
