Can electric shaver charge batteries installed with reversed polarity?
In summary, the batteries in the Braun electric shaver stopped holding a charge after being replaced with 2-AA rechargeable batteries. The battery supplier claims that this symptom is classic for reversed polarity, but it's unclear whether this is the case. The voltmeter test showed that the batteries were correctly polarity.
cjben
Hi,
I bought 2-AA (with pins tabs) rechargeable batteries for a Braun electric shaver. Checked the polarity of the old batteries, marked it on the board, and soldered the new batteries accordingly. (In series.)
First charge lasted 4 weeks. Next 3-4 charges lasted less and less. Now, batteries won't even hold a charge overnight.
Battery supplier claims that this symptom is classic for reversed polarity...
Does this make sense? Any thoughts? Could the old batteries have themselves become reversed in polarity? What can be tested at this point?
Thank you,
Ben
Well I don't explicitly know, but this is my thought about it =)
Battery cells store energy in a very interesting way. You have the two sides, the anode and cathode, which are made up of metals and between them lies a, usually, alkali solution. When you connect the end of the battery and complete a circuit. The anode dissolves forming positive ions, since it is a metal, and the electrons give you your current for whatever you have plugged the batteries into. When you recharge you reverse the process by supplying electricity which reforms the anode, but you effectively switch the anode and cathode doing this thus reversing the polarity. And the reason that they recharge less is because some of the ions from the previous anode and cathodes becomes atoms whilst still in the fluid so no longer carry a charge.
The way i would test this theory is by creating a battery myself, bigger, so I could see what happens... but I think the supplies would be difficult to get because you'd eed an appropriate anode, cathode and electrolyte. What do you think?
Check polarity of batteries with voltmeter.
Is polarity of batteries opposite that marked on batteries?
Its hard for me to imagine a consumer product whose batteries are not user replaceable (require soldering) accommodating arbitrary battery polarity.
How many consumer products where batteries *are* user replaceable work when batteries put in wrong way around?
My guess is that you got some inferior or wrong chemistry batteries.
Thanks for the thoughts. I'm out of town right now, but will check the polarity of the batteries with a volt meter. The "+" and "-" were hand-written in by the manufacturer, and both ends are identically flat, unlike store-bought batteries. So, perhaps they were written incorrectly? Or, if I have reverse-charged them, what will the voltmeter show?
I wonder if there is some circuitry in the shaver to prevent reverse polarity charging. The shaver seems to run 'hotter' than before while charging. It's amazing to me that there are no circuit diagrams to be found on the internet-- it's as if Braun has done a solid job to keep any technical information to themselves.
Related to Can electric shaver charge batteries installed with reversed polarity?
1. Can an electric shaver charge batteries that are installed with reversed polarity?
Yes, an electric shaver can charge batteries that are installed with reversed polarity. However, it is not recommended as it can damage the batteries and the shaver.
2. What happens if I install the batteries with reversed polarity in my electric shaver?
If you install the batteries with reversed polarity in your electric shaver, it will not work properly and may also damage the batteries. It is important to always check the correct polarity before installing batteries in any device.
3. How can I tell if the batteries in my electric shaver have reversed polarity?
You can tell if the batteries in your electric shaver have reversed polarity by checking the positive and negative symbols on the batteries and matching them with the corresponding symbols on the shaver. If the symbols do not match, the batteries are installed with reversed polarity.
4. Is it safe to use an electric shaver with batteries installed with reversed polarity?
No, it is not safe to use an electric shaver with batteries installed with reversed polarity. It can cause damage to the batteries and the shaver, and may also pose a safety hazard. It is important to always use batteries with the correct polarity to ensure safe operation of your electric shaver.
5. How can I avoid installing batteries with reversed polarity in my electric shaver?
To avoid installing batteries with reversed polarity in your electric shaver, always check the positive and negative symbols on the batteries and match them with the corresponding symbols on the shaver. Additionally, make sure to insert the batteries in the correct direction as indicated by the diagrams or instructions provided by the manufacturer.
  • Other Physics Topics
