Can electricity be made from diesel?
In summary, generators use a residual magnetic field to self-excite and produce electricity. Without this field, the generator would not produce power.
stickythighs
37
I went to a traveling carnival a few weeks ago, and I noticed that the carnival had several generators to power the rides. My guess is the generator ran off either diesel or gasoline in order to make electricity, although the electricity from the generator might have came from a battery.
Can a generator without a battery create electricity from diesel fuel?
Can a generator without a battery create electricity from gasoline?
Computer science news on Phys.org
The method of turning the generator (or alternator) doesn't matter.
It can be diesel, gasoline, water power, or even a hand crank.
Generators have a residual magnetic field that allows them to self excite.
If for some reason the generator becomes completely demagnetized then a battery or some other electrical source is required to remagnetize it.
Some have permanent magnets as well for the initial excitation.
CS
notime and stewartcs,
I'm guessing that the diesel fuel is to start an engine in order to create mechanical power. The generator then turns the mechanical energy into electrical energy. Is this correct?
I am not sure what you mean when you say that some have permanent magnets for the initial excitation. Do you mean that a magnet is used to start the engine?
The diesel fuel is the chemical energy source for the mechanical energy (the prime mover in a generator) that will be converted into the electrical energy.
In order for the generator to produce useable electrical power, the armature must be excited by a separate field. The field poles are energized by residual magnetism, an external source such as a battery, permanent magnets, self-excitation, or possibly some combination.
Here is a little info on field excitation:
http://en.wikipedia.org/wiki/Excitation_(magnetic)
To get the prime mover rotating, you'll need some type of starter. This may be another electrical source such as a bus (electrical bus that is), batteries, air, etc.
Hope that helps.
CS
FAQ: Can electricity be made from diesel?
Can diesel be converted into electricity?
Yes, diesel can be converted into electricity through the use of a generator. The generator burns diesel fuel to produce mechanical energy, which is then converted into electrical energy.
How does diesel produce electricity?
Diesel produces electricity through a process called combustion. This involves burning the diesel fuel, which releases energy in the form of heat. The heat then turns water into steam, which drives a turbine to produce electricity.
Is diesel a renewable source of electricity?
No, diesel is not considered a renewable source of electricity because it is made from fossil fuels, which are non-renewable resources. However, there are some efforts to produce diesel from renewable sources such as vegetable oils and animal fats.
What are the advantages of using diesel for electricity?
Diesel is a reliable and efficient source of electricity, as it can produce large amounts of energy at a consistent rate. It is also readily available and can be easily transported, making it a popular choice for remote or off-grid areas.
Are there any environmental concerns with using diesel for electricity?
Yes, there are some environmental concerns with using diesel for electricity. The combustion of diesel fuel produces emissions such as carbon dioxide, which contributes to climate change. It also releases pollutants such as nitrogen oxides and particulate matter, which can harm human health and the environment.
