Can electrons pile up in a conductor
In summary, the potential charge of an electret is calculated by multiplying the capacitance (in Farads) by the voltage (in volts) across the capacitor.
smiddleton
Hey All,
I'm new to the forum. I hope I put this in the right area of expertise. If not, I would appreciate it if you could direct me to the right place. I am just a curious person with a pretty good physics background but I came up with a question I couldn't answer. Hypothetically, if you had a 2 inch long straight copper wire, and some how created a positive force at localized at 1 end of the wire, would the electrons in the wire that are "mobile" move toward that end and sort of pile up in a large, well, pile, of electrons? Or would only the electrons on the surface of the wire move toward that point? I hope that makes sense. Thanks advance, I hope you don't mind me pondering physics as a hobby.
SM
I just join in the discussion. I believe it will. What you are asking is in any EM book where you put an +E field at one end of the wire. The electrons are attracted to that end of the wire. The other end is left with excess of protons and become +ve charged.
This should be same as a hollow conductor ball with a +ve charge in the middle. electrons will be pull the the inner surface and the outer surface has the +ve charge. The total +ve charge on the outer surface is equal to the charge inside the ball. The total charge in the conductor ball is neutral.
But there is no potential difference between the two ends of your 2" wire as any potential will cause electrons to move to neutralize the potential.
Any constant electric field accompanies a linearly varying potential field. Its seen from Poisson's equation.
This reminds me of a question I was asked many years ago.
"Imagine a straight copper wire placed above a bowl. A current was flowing through the wire when the wire is suddenly cut in the middle. Will the electrons drop from one end of the wire into the bowl below?" :smile:
Not in a conductor, any field inside the conductor will cause electrons to move in direction to neutralize the potential. This is explained very clear in any of the EM textbook.
Oops! I overlooked this thing. Electric field decays inside a conductor and reduces to 1/e at skin depth. Roughly yungman is correct.
It is more than that, you are referring to varying E field that has skin depth. Even in total static E, there cannot be E inside a good conductor as any E will cause the electrons to drift to neutralize any the field.
Actually I made a mistake in my first post also. It's not potential, it's E field cannot exist inside a good conductor. I edited my first post already to cover the evidence!:smile:
Well ! Years of lack of practice of EM is producing some effects. haha. Don't worry. I'll catch up.
That's how it is. I could have answer better a year ago when I was hot on the trod with studying EM. I have been off for like a year, I swear I really forgot a lot of things.
smiddleton, Welcome to Physics Forums!
Yes, a positive charge will attract free electrons in a conductor! You are exactly correct. If you Google "electrostatics" you can read all about this subject at the Wikipedia page. Especially check out the diagram about half-way down the page. It shows what you are describing graphically and clearly!
http://en.wikipedia.org/wiki/File:Electrostatic_induction.svg
Wow, thanks for all the replies. I love physics, but I went into materials science so my electrical engineering background is pretty basic. This really helps though, thanks everyone!
SM
Hey guys, I have another quick question. How do you calculate the potential charge, in coulombs, of an electret? I can't find that one anywhere. Thanks again.
SM
Also, how do they calculate the voltage? I think my understanding of distance in parallel plate caps is making it hard for me to understand this. Thanks.
SM
If you bring an electric charge close to a copper wire the electrons in the entire wire would start moving, not just at the surface. That's why the resistance of a wire depends on it's cross sectional area and not on it's circumference. As soon as the field inside the wire has dropped to zero the electrons stop moving. One end of the wire will then be charged positive and the other negative. btw. there can be a field inside a conductor if there is a current flowing.
An electret is similar to a charged parallel plate capacitor, just without the plates. So voltage is equal to field strength * thickness. The charge is field strength * electric field constant * area * dielectric constant.
FAQ: Can electrons pile up in a conductor
Can electrons pile up in a conductor?
Yes, electrons can pile up in a conductor. This is known as electron accumulation and occurs when there is an excess of electrons in a particular area of the conductor.
How does electron accumulation occur in a conductor?
Electron accumulation in a conductor occurs when there is an imbalance between the number of electrons entering and leaving a particular area of the conductor. This can be caused by an external source, such as a battery, or by the movement of electrons within the conductor itself.
Is electron accumulation in a conductor a common occurrence?
Yes, electron accumulation is a common occurrence in conductors, especially in electrical circuits. The flow of electrons is essential for the proper functioning of many electronic devices.
What are the effects of electron accumulation in a conductor?
The effects of electron accumulation can vary depending on the specific situation. In some cases, it can lead to a buildup of static electricity, which can cause shocks or damage to electronic components. In other cases, it may be necessary for the proper functioning of a device, such as in a transistor.
How is electron accumulation in a conductor managed or controlled?
Electron accumulation can be managed or controlled by using various techniques, such as grounding the conductor or using resistors to limit the flow of electrons. In electronic circuits, components such as transistors and capacitors are used to control the flow of electrons and prevent excess accumulation.
