Can energy be condensed and/or bridged?
In summary, this concept of potential energy opens up a lot of interesting possibilities, but it is not actually possible to have infinite potential energy.
Vectory
This is something that has come to mind and I would want to hear what you other enthusiasts also think about it if you find it at all intruiging. The concept I am thinking about can be applied to a variety of processes but once the extent at which the idea surpasses customary principles it becomes quite enigmatic. What happens to an item that gains potential energy and is forced to keep increasing inherent power with an infinite capacity, but is also kept from transferring into kinesis. How would a capacitor react? Can energy be condensed and/or bridged?
Well, a capacitor can only hold so much charge depending on design. Then it either stops being able to be charged, or it is destroyed.
Infinite capacity, in this context, is not possible.
If you continue to pour energy into a real-world system, you reach a point where
a) the system runs out of capacity or b) you run out of energy.
If you postulate the availability of infinite capacity and infinite energy you would need an infinite universe both to supply it and to contain it.
Thinking about it, probably one wouldn't be enough...
Well ofcourse for a finite system but how much energy can be infinite in power
Well, power is the rate-of-doing-work, which is the same as the-rate-of-storing-energy.
So for infinite power, you would have to store infinite energy, infinitely fast...
That sounds remarkably like the moment of creation of an infinite universe. or possibly the destruction of one. :biggrin:
I guess what is 'potential' energy versus what is 'kinetic' energy is relative. If you pour an infinite amount of energy into accelerating an object, it will keep absorbing that energy (faster speed/bigger mass). Relative to you the object transfers that energy into kinetic energy but relative to itself, it is not moving and it is all potential energy.
Of course Einstein then would have to say that the mass increases to an infinite size and consumes the entire universe.
This is a silly topic and I shouldn't have contributed, but I can't let that pass, it's fallacious.
Not only that, it perpetuates the OP's initial misunderstanding.
Energy isn't some thing like a liquid that you can pour from one place to another, it's a book-keeping device that we use to keep track of the movement of, and forces between objects.
Nor does an object exist in relation to something called the 'universe', it exists in relation to other objects. Energy is a measure of that relationship so that you cannot talk about the energy of an object, only it's energy in relation to another.
In a 'universe' that consisted of just two objects, moving relative to each other, one would have an energy (classically) of 1/2mv^2 relative to the other. The other would have an energy of 1/2mv^2 relative to the first.
(K.E. is vectorial so the two energies would be directed in opposite directions, making the vector sum zero.)
The energy of either object, relative to a third would be a function of it's relative velocity. Every time you move the frame of reference, you change the zero point for measurement of energy.
Since an object doesn't move relative to itself, it's KE relative to itself is zero. Potential energy doesn't come into it.
AJ Bentley said:
this is a silly topic:
I kind of like this topic actually, it's a nice philosophical "What if" question. It's good to think this way to give additional points of view. For instance, if we say that body A accelerates away from body B, then A acquires a Kinetic energy relative to B. But as you say, relative to A, it is not moving and has no kinetic energy - but from its point of view, B has the kinetic energy since it appears to be the one accelerating away. In other words, to each, the 'other' has the kinetic energy. In this respect, and according to a 'relativistic' point of view, you are completely right. Neither has any 'potential' energy.
However...stepping outside the 'norm' for a moment and contemplating and interesting point of view (not according to the books necessarily), in the scenario above, only A would have experienced the force of acceleration. This force of acceleration is non-inertial movement. This non-inertial movement then means that the Principle of Relativity cannot apply to the situation and the experience of the object in one frame of reference cannot be translated into the experience of the other, since this Principle fails when trying to explain non-inertial movement. Similar to what we see with the Twin Paradox, object A in this case "COULD" be considered the one to have received all the energy that was transferred from some other form, and not B, because only A felt the non-inertial movement. So from a philosophical point of view, one could scratch their head and think that A must have increased in energy somehow and not B, hence acquiring what might be described as a type of potential - or even 'rest' energy.
Keep in mind that the twin paradox is only a paradox when the non-inertial movement is ignored. Most people agree that the paradox goes away when taking the acceleration into account but then the debate between absolute vs relative space ensues. The "Absolute relativism" versus "Absolute space" debate is still not resolved, however, many think it is solved simply because they sit on one side and are convinced of their own point of view. Regardless, the debate continues with strong arguments on both sides, so it is not certainly wrong to consider that the situation is not perfectly relative.
In the end, your argument depends on the fact that the points of view between A and B are perfectly relative - which would require that no non-inertial movement was involved, but this is not the case.
lenfromkits;2784669In the end said:
I don't mind a bit of tongue-in-cheek banter between Illuminati. (Got you there spell-checker!)
But there are children listening, you have to be careful.
There are quite a few high-school kids on the forum who are clearly struggling a bit with basic concepts. I don't think its fair to confuse them or lead them on into misconceptions. The subject matter is difficult enough.
I don't doubt you know what you mean, and I'm quite prepared to follow you to the door, but I'm not going down that road.
Ha, talk about a come-back argument that is 'out of the box.' Yeah, it's a good point. But I guess the nature of the original comment on this particular thread wasn't really a high school type of question and was more of a thought-inducing philosophical question.
Related to Can energy be condensed and/or bridged?
1. Can energy be condensed?
Yes, energy can be condensed through various processes such as compression, cooling, and chemical reactions.
2. Can energy be bridged?
Yes, energy can be bridged or transferred from one form to another through various mechanisms like electromagnetic radiation, heat transfer, and mechanical work.
3. Is it possible to condense and bridge energy simultaneously?
Yes, energy can both be condensed and bridged at the same time. For example, in a power plant, energy is first condensed from steam to water and then bridged to electricity through a turbine.
4. What are the benefits of condensing and bridging energy?
The benefits of condensing and bridging energy include efficient use of resources, reduced environmental impact, and increased availability of energy for various applications.
5. Are there any limitations to condensing and bridging energy?
Yes, there are limitations to condensing and bridging energy, such as the laws of thermodynamics which state that energy cannot be created or destroyed, only transferred. Additionally, some forms of energy may be difficult or impossible to bridge, such as nuclear energy.
