Can energy truly be converted into matter in our world?
Energy can theoretically be converted into matter if the process is reversible, a concept rooted in relativistic particle physics. Particle collision experiments at facilities like CERN demonstrate this by smashing protons to create heavier particles, showcasing kinetic energy transforming into mass-energy. Conversely, larger particles often decay into lighter ones, illustrating mass-energy converting back into kinetic energy. Fusion processes that produce elements heavier than iron also exemplify this conversion, as the resulting mass exceeds the sum of the initial masses due to kinetic energy. Pair production further illustrates this concept, where gamma rays convert energy into particle-antiparticle pairs near a nucleus.
Any name will do
I am not a student; I have no homework to do; yet it's a research question I would like to ask to satisfy my own curiosity.
The question is: "We can turn matter into energy, by reducing the total mass in a nuclear fission, in which the loss of mass gets converted into energy according to the famous equation by Albert Einstein. However, have we, humans, ever produced an event in which energy turns into mass? Or have we ever observed such an event in which an energy loss creates matter? Do we have any theories how that may be done or caused to happen? and if yes, we do have widely-accepted theories by peers that describes how that could happen or be done, then could you please describe that event here as an answer, in terms that are understood by a physics-dilettante?"
I have prep school education in physics, which mainly involved classical physics (kinetics, mechanics, waves, harmonic motion, heat-pressure-volume equivalencies, etc.) I have no experience studying relativity physics or quantum physics. By prep-school education I meant that I finished grade 13 physics in Ontario in 1974, which at the time was an advanced high school subject, preparing pupils to enter university and take higher-level courses without the need to take prerequisites.
m=e/c^2
Theoretically possible, only if the process is reversible. But is it really. My knowledge base is insufficient to answer that. I need help.
Turning energy into matter and vice versa is something of an imprecise statement of relativistic particle physics. In particle collision experiments (that are routinely done at CERN and other particle accelerators):
1) Particles with a small rest mass (e.g. protons) are smashed together to produce a particle or particles with a greater total rest mass. You could describe this as kinetic energy being converted into mass-energy.
2) The larger particles (which are often short-lived) decay into particles with less rest mass (and more kinetic energy). You could describe this as mass-energy being converted into kinetic energy.
Likes Any name will do and Ibix
Fusion that forms anything heavier than iron results in atoms that have a larger mass than the sum of the masses of their inputs; the difference comes from the kinetic energy of the initial atoms/ions. So the production of about half the periodic table in supernovae is another example.
Likes phinds, Any name will do and PeroK
Thank you, PeroK and Ibix. Your answers have fully satisfied my curiosity.
Likes berkeman, Ibix and PeroK
Not to ignore pair production wherein the energy of a (zero mass) gamma ray is converted into a massive particle-antiparticle pair in the vicinity of a nucleus.
Likes Any name will do, Ibix and PeroK
Thanks also to you, Kuruman.
Likes kuruman and berkeman
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
