Graduate Can entanglement be detected in a single Bell pair?
Entanglement in a single Bell pair cannot typically be detected; it is usually observed in an ensemble of Bell pairs using the CHSH formula, where an S value greater than 2.00 indicates entanglement. However, recent experiments utilizing weak measurements allow for the calculation of the Bell parameter for individual pairs, revealing that most pairs exhibit entanglement with an average S value close to theoretical expectations. This method enables sequential measurements on the same quantum state without complete wave function collapse, addressing the freedom-of-choice loophole. The findings suggest that significant entanglement remains even after measurement, enhancing the potential for further quantum protocols. This breakthrough represents a significant advancement in quantum measurement techniques.
DrChinese
The canonical answer is NO, you can only see the entanglement in an ensemble of Bell pairs. For example, you could look at a stream of photon pairs coming from a PDC source. If you apply the CHSH formula (usually presented as an "S" value) on the observed dataset (perhaps consisting of hundreds or thousands of data points), then you might observe S=2.50 for the full ensemble. S>2.00 confirms that entanglement is present. The upper limit (Tsirilson bound) is 2.82.
However, a recent experiment using so-called "weak measurements" does in fact allow S to be measured and presented for each and every Bell pair. A weak measurement is one in which there is only partial collapse* of the wave function. By way of analogy: when a person walks through a door that is 3 meters high by 1 meter wide, a weak measurement of that person's height and width is being performed. You know that person is no more than 3 meters tall by 1 meter wide, but you don't know more precisely than that.
In the quantum laboratory world, most observations are intended to yield high precision. But when a weak measurement is done, you can perform additional tests on a particle and gain additional information. In our example of a person going through a door: suppose after walking through the door, there was scale to measure the person's weight. The weight, coupled with outcome of the previous weak size measurement, might give you a lot more information than can be deduced from the individual measurements alone.
In the experiment, an S value is calculated on each individual pair of over 1,000,000 pairs. See the (partial) plot of those values in Fig. 2. Although there were values of S that did not indicate entanglement, most did. The average S value was -2.79+/-0.18, very close to the theoretical expectation value.
https://arxiv.org/abs/2303.04787
Single-pair measurement of the Bell parameter
Salvatore Virzì, Enrico Rebufello, Francesco Atzori, Alessio Avella, Fabrizio Piacentini, Rudi Lussana, Iris Cusini, Francesca Madonini, Federica Villa, Marco Gramegna, Eliahu Cohen, Ivo Pietro Degiovanni, Marco Genovese (2023)
Abstract: "Bell inequalities are one of the cornerstones of quantum foundations, and fundamental tools for quantum technologies. Recently, the scientific community worldwide has put a lot of effort towards them, which culminated with loophole-free experiments. Nonetheless, none of the experimental tests so far was able to extract information on the full inequality from each entangled pair, since the wave function collapse forbids performing, on the same quantum state, all the measurements needed for evaluating the entire Bell parameter. We present here the first single-pair Bell inequality test, able to obtain a Bell parameter value for every entangled pair detected. This is made possible by exploiting sequential weak measurements, allowing to measure non-commuting observables in sequence on the same state, on each entangled particle. Such an approach not only grants unprecedented measurement capability, but also removes the need to choose between different measurement bases, intrinsically eliminating the freedom-of-choice loophole and stretching the concept of counterfactual-definiteness (since it allows measuring in the otherwise not-chosen bases). We also demonstrate how, after the Bell parameter measurement, the pair under test still presents a noteworthy amount of entanglement, providing evidence of the absence of (complete) wave function collapse and allowing to exploit this quantum resource for further protocols."*I am using "collapse" in the same manner in which the paper's authors use the term. I am not using it in a manner that might favor one QM interpretation over another.
Likes Isaac Hart, DennisN, Demystifier and 5 others
The catch is large uncertainty. As they say in Introduction: "Our result represents a breakthrough application of them, since, for the first time, they allow evaluating the entire Bell parameter individually from each entangled pair detected (although with a large uncertainty, typical of weak measurements)." Fig. 2 illustrates well how large this uncertainty is.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 58 ·
  • · Replies 55 ·
  • · Replies 80 ·
