MHB Can Every Integer Be Decomposed into an Odd Integer and a Power of 2?
Every natural number can be expressed as a product of an odd integer and a non-negative integer power of 2. For odd integers, this is straightforward as they can be represented as n multiplied by 2^0. Even integers, including zero, can be factored into 2 raised to a positive integer and another integer. The discussion emphasizes the importance of including 1 as an odd factor when considering powers of 2. A proof can be constructed using repeated division by 2 and strong induction to validate this claim.
KOO
Prove that every n E N can be written as a product of odd integer and a non-negative integer power of 2.
For instance: 36 = 22 * 9
If n is odd, we can write it as \displaystyle \begin{align*} n = n \cdot 2^0 \end{align*}.
If n is even (including 0), it must have a factor of 2, so we can write it as \displaystyle \begin{align*} n = 2^1 k \end{align*}.
Q.E.D.
This is not enough to prove the required claim.
What about powers of 2? 2^k (k being a positive integer) has no odd factors, unless you want to include 1.
-Dan
Well, we want to include 1. Thus, if $k$ is a nonnegative integer, then $2^k=1\cdot2^k$: here 1 is an odd integer and $2^k$ is a non-negative integer power of 2, so this factorization satisfies the problem statement.
Obviously, a proof of this fact uses repeated division by 2. It can be made precise using strong induction.
There was https://driven2services.com/staging/mh/index.php?posts/33828/ here about MathStackExchange (MSE), and the format that encourages dialogue was mentioned as a feature that distinguishes this forum from MSE. So I suggest that the OP write his/her reaction to what has been said so far and also the topic that this problem is supposed to teach (such as strong induction, direct proofs, or divisibility).
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
