MHB Can Every Natural Number be Expressed as a Sum of Square Roots?
  • Thread starter Thread starter anemone
    Radicals
anemone
MHB
POTW Director
Prove that for any natural number $a$, there is an integer $k$ such that $(\sqrt{1982}+1)^a=\sqrt{k}+\sqrt{k+1981^a}$
Mathematics news on Phys.org
We can actually solve this for $k$ directly:
$$(\sqrt{1982}+1)^a=\sqrt{k}+\sqrt{k+1981^a}$$
$$(\sqrt{1982}+1)^a - \sqrt{k}=\sqrt{k+1981^a}$$
$$\left ((\sqrt{1982}+1)^a - \sqrt{k} \right )^2=k+1981^a$$
$$(\sqrt{1982}+1)^{2a} - 2 \sqrt{k} (\sqrt{1982}+1)^a + k=k+1981^a$$
$$(\sqrt{1982}+1)^{2a} - 2 \sqrt{k} (\sqrt{1982}+1)^a = 1981^a$$
$$2 \sqrt{k} (\sqrt{1982}+1)^a = (\sqrt{1982}+1)^{2a} - 1981^a$$
$$\sqrt{k} = \frac{(\sqrt{1982}+1)^{2a} - 1981^a}{2 (\sqrt{1982}+1)^a}$$
Now just note that:
$$\left (\sqrt{1982} - 1 \right ) \left (\sqrt{1982} + 1 \right ) = 1981$$
And so we get:
$$\sqrt{k} = \frac{(\sqrt{1982}+1)^{2a} - \left (\sqrt{1982} - 1 \right )^a \left (\sqrt{1982} + 1 \right )^a}{2 (\sqrt{1982}+1)^a}$$
We can now divide through to get:
$$\sqrt{k} = \frac{1}{2} \left [ (\sqrt{1982}+1)^a - \left (\sqrt{1982} - 1 \right )^a \right ]$$
And finally:
$$k = \frac{1}{4} \left [ (\sqrt{1982}+1)^a - \left (\sqrt{1982} - 1 \right )^a \right ]^2$$
Expanding:
$$k = \frac{1}{4} \left [ (\sqrt{1982}+1)^{2a} + \left (\sqrt{1982} - 1 \right )^{2a} - 2 \cdot 1981^a \right ]$$
Finally we use the binomial theorem to expand the powers:
$$\left ( \sqrt{1982} + 1 \right )^{2a} + \left (\sqrt{1982} - 1 \right )^{2a} = \sum_{k = 0}^{2a} \binom{2a}{k} \left [ \sqrt{1982}^{2a - k} + \sqrt{1982}^{2a - k} (-1)^k \right ]$$
Now for odd $k$ the $k$th term vanishes, so consider only even $k$, say $k = 2m$:
$$\left ( \sqrt{1982} + 1 \right )^{2a} + \left (\sqrt{1982} - 1 \right )^{2a} = \sum_{m = 0}^{a} \binom{2a}{2m} \sqrt{1982}^{2a - 2m} + \sqrt{1982}^{2a - 2m} = \sum_{m = 0}^{a} \binom{2a}{2m} 2 \cdot 1982^{a - m}$$
So that the sum is clearly an integer. Note that 1982 is even, so that all the terms in the series except the last (which is always just $(2a, 2a) 2 \cdot 1982^0 = 2$) are divisible by 4, so that the sum as a whole is divisible by 2 but not by 4. On the other hand, $2 \cdot 1981^a$ is also divisible by 2 but not by 4, and so:
$$(\sqrt{1982}+1)^{2a} + \left (\sqrt{1982} - 1 \right )^{2a} - 2 \cdot 1981^a ~ ~ ~ \text{is divisible by 4}$$
We conclude that:
$$k = \frac{1}{4} \left [ (\sqrt{1982}+1)^{2a} + \left (\sqrt{1982} - 1 \right )^{2a} - 2 \cdot 1981^a \right ] = \frac{1}{4} \left [ (\sqrt{1982}+1)^a - \left (\sqrt{1982} - 1 \right )^a \right ]^2$$
is in fact an integer and a solution to the original equation as derived earlier. $\blacksquare$
First few solutions $(a, k)$ are given by $(0, 0), (1, 1), (2, 7928), (3, 35366809), (4, 124700748768), \cdots$
Hi Bacterius, sorry for the late reply, and thanks for the great solution!:)
I also want to share the solution (of other) here:
Let $$X=\sum_{j=o\,\,j\,\,\text{even}}^{a} {a\choose j}(\sqrt{1982})^j$$, $$Y=\sum_{j=o\,\,j\,\,\text{odd}}^{a} {a\choose j}(\sqrt{1982})^j$$
Thus $X$ is the sum of the even-numbered terms in the expansion of $(\sqrt{1982}+1)^a$ and $Y$ is the sum of the odd-numbered terms in that expansion.
Note also that
$$(\sqrt{1982}-1)^a=\sum_{j=o}^{a} {a\choose j}(\sqrt{1982})^{a-j}(-1)^j=\begin{cases}Y-X \,\,\,\text{if}\,\,a\,\,\text{is odd}, & \\[3pt] X-Y \,\,\,\text{if}\,\,a\,\,\text{is even} \\ \end{cases}$$
Case 1: $a$ is odd. Let $k=X^2$
Then we have
$\begin{align*}\sqrt{k+1981^a}+\sqrt{k}&=\sqrt{X^2+(\sqrt{1982}-1)^a(\sqrt{1982}+1)^a}+X\\&=\sqrt{X^2+(Y-X)(X+Y)}+X\\&=\sqrt{X^2+Y^2-X^2}+X\\&=Y+X\\&=(\sqrt{1981}+1)^a \end{align*}$
Case 2: $a$ is even. Let $k=Y^2$
Then we have
$\begin{align*}\sqrt{k+1981^a}+\sqrt{k}&=\sqrt{Y^2+(X-Y)(X+Y)}+\sqrt{Y^2}\\&=\sqrt{X^2}+\sqrt{Y^2}\\&=(\sqrt{1981}+1)^a \end{align*}$
It's evident that $X^2$ is an integer, and $Y^2$ is an integer since $Y$ has the form $\sqrt{1982}M$, for some integer $M$, and this completes the proof.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
