A Can falling factorials be a Schauder basis for formal power series?
lugita15
We usually talk about ##F[[x]]##, the set of formal power series with coefficients in ##F##, as a topological ring. But we can also view it as a topological vector space over ##F## where ##F## is endowed with the discrete topology. And viewed in this way, ##\{x^n:n\in\mathbb{N}\}## is a Schauder basis for ##F[[x]]##.
Now in contrast, ##\{(x)_n:n\in\mathbb{N}\}##, where ##(x)_n## denotes the falling factorial, is not a Schauder basis for ##F[[x]]##. That’s because if ##\Sigma_na_n(x)_n## never converges in the standard topology on ##F[[x]]## if infinitely many of the ##a_n##’s are nonzero. But my question is, does there exist some alternate topology on ##F[[x]]## which makes ##\{(x)_n:n\in\mathbb{N}\}## a Schauder basis for ##F[[x]]## as a topological vector space over ##F## endowed with the discrete topology?
A schauder basis per the wikipedia article is typically defined based on a norm, which I think means you don't get to pick any particular topology on the field. Do you only care about topologies defined by a norm on the vector space, or would any topology that happens to permit you to compute unique limits suffice?
I’m not interested in normed vector spaces at all. As Wikipedia says “Schauder bases can also be defined analogously in a general topological vector space.”
It feels like the answer has to be no, but it's tough. For example can you just define a topology where the sequence ##\sum_{i =0}^n a_i(x)_i## converges to ##\sum_{0}^{\infty} a_i x^i##? I poked around a little bit and can't generate an obvious contradiction where you just assume the normal topology on the polynomials and then pick some open sets around the infinite series that make those limits true.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
10K
12K
