Can Gas Expansion Be Reversed?
In summary, the conversation discusses the question of how to determine work, W, in a given situation involving the expansion of an ideal monatomic gas. The question provides information on the initial and final states of the gas, but does not specify whether the expansion is reversible or irreversible. The conversation then explores the three types of expansion typically discussed, isentropic, isothermal, and isobaric, and determines that the expansion in this question is most likely isobaric. Using this assumption, the work can be calculated using the formula P_{ext} \int dV = P_{ext} (V_{final} - V_{initial}). Another potential path to calculate work could be through a polytropic (reversible) path described
Oribis
Hello, new here! I have a question regarding reversible or irreversible expansions in regards to figuring which equation is needed to figure out work, W. For starters, here is the question:
One mole of an ideal monatomic gas is expanded from an initial state of 3 atm and 500 K to a final state of 1 atm and 300 K. Calculate w, q and ∆U.
Note: Approximate 1 atm  1 x 105 Pa. For an ideal monatomic gas, Cv = 3R/2 and Cp = CV + nR.
So below, I know of two different equations for w,
dw = − pex × dV for an irreversible expansion and
Wrev =−nRT Vf ∫ Vi 1/v dV=−nRTln Vf/Vi for a reversible expansion.
I have looked at a few factors in the question, most research points to w = -Pex X dv but no explanation as to why. I also know it is not isothermal or isobaric based on the info above.[/B]
Since the question did not specify reversible or irreversible, which should I use and how should I know how to understand for future reference? Thanks for the help!
If you are only given the initial state and final state, then you can't compute the work, because the work depends on the path (that is, it depends on how you get to the final state). So the question must assume that there is some standard way to do the expansion.
Typically, there are three types of expansion that are usually discussed (although you could certainly have weirder types):
  1. Isentropic: You expand the gas reversibly, not allowing heat to enter or leave.
  2. Isothermal: You expand while keeping the temperature constant.
  3. Isobaric: You expand while keeping the external pressure constant.
Neither of your formulas correspond to #1, and #2 is out, because the temperature changes. So I think that the expansion must be #3, isobaric. You seem to think that it can't be isobaric, since the pressure changes from 3 atm to 1 atm, but irreversible isobaric means that the external pressure is kept constant, not the internal pressure. Think of having a container of gas under 3 atm pressure, then you open the container into the room. The external pressure is 1 atm the whole time, while the internal pressure decreases from 3 to 1 atm.
So if it's isobaric, then the work done is [itex]P_{ext} \int dV = P_{ext} (V_{final} - V_{initial})[/itex]. You can calculate [itex]V_{final}[/itex] and [itex]V_{initial}[/itex] from [itex]P_{final} V_{final} = N R T_{final}[/itex] and [itex]P_{initial} V_{initial} = N R T_{initial}[/itex]
This is certainly a viable path, consistent with the problem statement. Another interesting possibility would be to assume a polytropic (reversible) path described by ##pV^n=Const##, where n can be determined from the initial and final pressures and volumes. It would be interesting to see how these two results would compare.
Related to Can Gas Expansion Be Reversed?
1. What does it mean for a reaction to be reversible?
A reversible reaction is a chemical reaction in which the products can be converted back into the original reactants. This means that the reaction can proceed in both the forward and reverse directions.
2. How can I tell if a reaction is reversible?
A reaction is considered reversible if it is able to reach equilibrium, meaning that the concentrations of reactants and products remain constant over time. This can be determined by conducting experiments and observing the direction in which the reaction proceeds.
3. What factors affect the reversibility of a reaction?
The reversibility of a reaction can be affected by a variety of factors such as temperature, pressure, and concentration of reactants and products. These factors can influence the equilibrium constant, which determines the extent to which a reaction is reversible.
4. Can all reactions be reversed?
No, not all reactions are reversible. Some reactions are irreversible, meaning that the products cannot be converted back into the original reactants. This is typically due to the formation of a stable product or the release of a gas that drives the reaction in one direction.
5. How does the concept of reversibility relate to chemical equilibrium?
Chemical equilibrium is the point at which the forward and reverse reactions occur at equal rates, resulting in no net change in the concentrations of reactants and products. Therefore, the concept of reversibility is closely tied to equilibrium, as it determines whether a reaction can reach this state.
