Can geodesic deviation be zero while curvature tensor is not
In summary, geodesic deviation is a special case of applying the Riemann curvature tensor, which gives information about the change in a vector when parallel-transported around a "rectangle" formed by two vectors. This equation can determine the entire curvature tensor for Riemannian manifolds, but for Lorentzian manifolds, there may be degenerate 2 planes and the proof for determining the whole curvature tensor is not as straightforward. However, geodesic deviations can still provide valuable information about the curvature tensor.
Elnur Hajiyev
40
I understand(or assume understand) that geodesic deviation describes how much parallel geodesics diverge/converge on manifolds while moving along these geodesic. But is not it a definition for intrinsic curvature? If it is same as Riemann curvature tensor in terms of describing curvature, why there is two distinct notion to describe it?
Thanks.
Thanks.
Geodesic deviation is a special case of applying the Riemann curvature tensor.
The informal meaning of the curvature tensor is this:
Make a "rectangle" with sides given by vectors [itex]U^\mu[/itex] and [itex]V^\mu[/itex]. Take a third vector [itex]W^\mu[/itex], and parallel-transport it around the rectangle to get back to the start. Then the change in [itex]W^\mu[/itex] resulting from the parallel-transport is:
[itex]\delta W^\mu = R^\mu_{\nu \lambda \sigma} W^\nu U^\lambda V^\sigma[/itex]
Geodesic deviation only gives you information about the special case in which [itex]W = V[/itex]; the vector that you are parallel-transporting around the rectangle is the separation vector between the sides of the rectangle.
Likes Elnur Hajiyev and andrewkirk
I am not sure about Lorentzian manifolds but for Riemannian manifolds the entire Riemann curvature tensor is determined by the sectional curvatures of tangential 2 planes.
These are the normalized curvatures ,##<R(X,Y)Y,X>/<X,X><Y,Y> - <X,Y>^2##.
The geodesic deviation equation ##D^2J/dt^2 = - R(J(t),c'(t))c'(t)## almost gives you the sectional curvature of the 2 plane spanned by ##J(t)## and ##c'(t)##. One only needs to take the inner product with ##J## and normalize. So for a Riemannian manifold one ought to be able to determine the entire curvature tensor from geodesic deviations. ( Note that sectional curvature is not defined for a degenerate 2 plane on a Lorentzian manifold.)
The variation vector field of a variation through geodesics is always a Jacobi field. That is: it always satisfies the geodesic deviation equation. One can always find a variation through geodesics that has an arbitrary Jacobi field as its variation vector field. This means that one can always compute ##R(J(t),c'(t))c'(t)## at any point along the geodesic in terms of some variation through geodesics. So for a Riemannian manifold the answer to your question is yes.
For a Lorentzian manifold I am not sure since there are degenerate 2 planes. Also the proof that every Jacobi field is the variation vector field of a variation through geodesics depends on the existence of a neighborhood of each point where each point is connected by a unique minimal geodesic. I tried to find a reference on line but without luck. I am sure one of the Relativity experts here would know the answer. In any case, the geodesic deviations ought to tell you a lot about the curvature tensor if not the whole thing. I would be interested to know the answer.
Related to Can geodesic deviation be zero while curvature tensor is not
1. Can geodesic deviation be zero in a curved space?
Yes, geodesic deviation can be zero in a curved space. This occurs when the geodesics (the shortest paths between two points) are parallel and do not diverge or converge.
2. What is geodesic deviation?
Geodesic deviation refers to the change in distance between two nearby geodesics (the shortest paths between two points) in a curved space. It is a measure of the curvature of the space.
3. How is geodesic deviation related to the curvature tensor?
The curvature tensor is used to describe the curvature of a space. Geodesic deviation is related to the curvature tensor through the geodesic equation, which describes how geodesics are affected by the curvature of a space.
4. Is it possible for geodesic deviation to be non-zero while the curvature tensor is zero?
Yes, it is possible for geodesic deviation to be non-zero while the curvature tensor is zero. This can occur in spaces with torsion, where the curvature tensor is zero but the geodesics still experience deviation due to non-metricity.
5. Can geodesic deviation be used to measure the strength of gravity in a space?
Yes, geodesic deviation can be used as a measure of the strength of gravity in a space. In general relativity, the curvature of spacetime is directly related to the presence of matter and energy, and geodesic deviation can be used to quantify this curvature and thus the strength of gravity.
  • Differential Geometry
  • Beyond the Standard Models
