MHB Can graph be used to solve inequalities without algebra?
  • Thread starter Thread starter mathdad
    Graph Inequality
The discussion focuses on using the graph of the polynomial y = x^4 - 4x^3 + 6x^2 - 4x + 2 to solve the inequalities x^4 - 4x^3 + 6x^2 - 4x + 2 < 0 and x^4 - 4x^3 + 6x^2 - 4x + 2 > 0 without algebra. The graph indicates that it crosses the y-axis at one point and does not touch or cross the x-axis, suggesting that the polynomial is always positive. Therefore, the inequality x^4 - 4x^3 + 6x^2 - 4x + 2 > 0 is satisfied for all x, while x^4 - 4x^3 + 6x^2 - 4x + 2 < 0 has no solutions. The graph effectively illustrates the behavior of the polynomial in relation to the inequalities.
mathdad
How do we use the graph to solve a given inequality.
For example, say the graph of y = x^4 - 4x^3 + 6x^2 - 4x + 2 is given. The graph of y crosses the y-axis at one point. It does not touch or cross the x-axis. In what way can the picture, the graph help us solve either of the following inequalities given below?
A. x^4 - 4x^3 + 6x^2 - 4x + 2 < 0
B. x^4 - 4x^3 + 6x^2 - 4x + 2 > 0
Remember, use the graph to solve. Do not solve algebraically. How is this done?
Mathematics news on Phys.org
Let's look at the graph as advised:
[DESMOS=-2.007008393275925,5.5746982450828035,-0.18167978042326505,2.4485740403429896]y=x^4-4x^3+6x^2-4x+2[/DESMOS]
Based on this, what values of $x$ appear to satisfy the two given inequalities?
By the way, do you recognize that:
$$y=(x-1)^4+1$$
The values of x? The graph does not touch the x-axis. It goes through one point on the line x = 0. I think 0 satisfies the inequality that is > 0 but does not satisfy the inequality where 0 is greater than the polynomial.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
