DyslexicHobo
- 251
Before I ask the question, I'd like to let you know why I am asking it; feel free to put in any input on the situation, as well as an answer to my question. Skip to the bottom if you don't want to know about it. :P
My class is designing a "toy for space" in joint with Russian students-- hosted by NASA.
For our toy, we're planning on designing some sort of RC flier designed to work on the space station. This will be just like an RC car, but will also be able to utilize the microgravity on the ISS.
So far, we've thought the best approach would be a cylindrical body with our propulsion at the back end. Direction will be controlled by air displacement of remotely controlled fins.
We thought we were fine and dandy until we realized that there was no way to stop the flier once it started changing direction. The momentum of the direction change would keep the flier going in the direction we wanted to nudge it in, with no simple way to stop it. We decided the easiest solution to this problem would be to increase the air resistance by adding wings 90 degrees apart from each other.
The next problem we encountered was slightly harder to overcome, but we think a gyroscope (or two) will help the problem. We realized that when--in zero gravity-- the fins are tilted one way to change the flier's direction, due to rotational inertia the flier will continue to spin unless some force counteracts it.
Now for my question: Will a set of gyroscopes (two, so all planes of motion are covered: x,y,z) stop our flier from over-rotating?And if you were wondering... we don't HAVE to build a prototype, nor do we have to have this perfected-- it's just for fun. However, if we do a good job, it'd be really cool to see if NASA would take this on at least the vomit comet and try it out in zero-Gees. :D
