Can hot water cool down through radiation?
In summary, EM radiation is created when particles collide, and it is a more efficient way to transfer heat than other forms of radiation.
gaurav_samanta
I have two more questions:-
(1) Can we calculate the time it takes specifically for water to radiate all its heat?
(2) Heat is illustrated as kinetic energy of molecules, so why collision between particles should result in the conversion of kinetic energy into radiation. Why conservation of momentum simply does not apply?
Science news on Phys.org
(1) We have Newton's law of cooling.
(2) Collisions of molecules do not play main role in generating radiation. Radiation comes mostly from vibration of molecule, not from translation motion of molecules.
gaurav_samanta said:
Summary:: What everyone tells me is that hot water transfers its energy to air. But I have also heard of water freezing down in the vacuum of space. How does that happen?
Most of it occurs by the boiling of part of the water. The lack of surrounding air pressure drops the boiling temperature of water to a very, very low temperature, and as some of the boil off they take energy with them, cooling off the remaining water.
The water will freeze first and then the ice will gradually sublimate and escape into space, eventually leaving nothing behind but a dispersed cloud of water vapor. Once this occurs the gas will either cool off or heat up depending on the environment that its in.
Molecules and atoms are composed of charged particles. Collisions of charged particles result in the acceleration (which includes deceleration) of said particles, and the acceleration of charged particles results in the creation of EM radiation. Kinetic energy from the particles is gradually turned into electromagnetic energy in the form of EM waves and the particles slow down overall as a result. Momentum is also transferred, as EM waves have momentum, so conservation of momentum holds up just fine.
Likes sysprog and FactChecker
I don't think Newton's law of cooling applies on radiation. Correct me if I am wrong.
Does that also happen in our macroscopic world? Do some materials tend to decelerate more than others? What's is this property of materials called?
Sure, all you need is a large, charged object. Unfortunately the intensity and frequency is proportional to the magnitude of the acceleration, and macroscopic objects can't be accelerated as hard as microscopic particles, so the emitted radiation is very hard to detect and of a very low frequency.
Sorry, I'm not sure what you're asking.
My question is does the intensity and frequency of radiation depends only on the mass of object and magnitude of the acceleration, or the chemistry of the object also has a role?
Also please tell me can we calculate the time it takes specifically for water to radiate all its heat?
Is 'Newton's law of cooling' the answer?
Is the math involved pretty complicated?
The efficiency with which a surface emits thermal radiation is called emissivity. The number is in relation to a theoretical maximum: a “black body”. The emissivity is a number between zero and one. Thermal radiation is a very strong function (##\Delta T^4##) of the temperature difference between the body in question and the environment into which it radiates. At large temperature differences (say, hot enough to glow) it can be the dominant way heat is transferred (standing near a bonfire, or pit of lava, or toasting bread). However at the temperature differences usually encountered in daily life thermal radiation transfers heat at a much slower rate than convection or conduction and often is ignored by comparison. However it isn’t completely negligible. If you do your best to suppress the others your coffee will still cool down faster than you want. A good example of this is a thermos bottle where they use a vacuum to suppress convection and conduction. ( still conductive losses at the neck.). If you get a chance to take one apart you’ll notice they coat the surfaces in shiny metal. This is to suppress the emissivity. It wouldn’t work nearly as well if they skipped that because thermal radiation still matters even at boiling water temperature differences. You can also see thermal radiation with a thermal camera. The whole world is glowing. At ~ 300K the glow is brightest at about 9 um. Animals which are only a few degrees warmer than the environment glow brightly.
Likes sysprog, gaurav_samanta and FactChecker
We can consider it from Stephen Botlzman law which says radiated energy per surface area per time is
[tex]E=\epsilon\sigma T^4[/tex]
So the differencial equation
[tex]S\epsilon\sigma T^4(t) dt + CdT(t)=0[/tex]
where S is area and C is specific heat capacity of the body, would hold meaning energy conservation.
Solving the equation
[tex]T(t)=[T_0^{-3}+\frac{3S\epsilon\sigma}{C} t]^{-\frac{1}{3}}[/tex]
where ##T_0=T(0)## initial temperature of the body and perfect vacuum, even 3K cosmic background radiation does not exist, surrounds the body. I derive it myself so please check it carefully.
Likes sysprog
It depends just on the magnitude of the charge and the magnitude of the acceleration. Mass and chemistry have nothing to do with the frequency or how much EM radiation is emitted from an accelerating charge (though mass will of course affect the rate of acceleration of a charged particle or object).
Likes sysprog
Newton's law of cooling does not work well for radiation.
The math for heat transfer can be simple or complex depending on the specifics of the scenario, the approach to solving it and desired accuracy of the model. You should describe for us a specific problem and we'll help you solve it.
Likes sysprog
Related to Can hot water cool down through radiation?
1. Can hot water cool down through radiation?
Yes, hot water can cool down through radiation. Radiation is a form of heat transfer in which energy is emitted in the form of electromagnetic waves. When hot water is exposed to cooler surroundings, it will emit radiation in the form of infrared light, causing it to lose heat and cool down.
2. How does radiation cause hot water to cool down?
Radiation causes hot water to cool down by emitting energy in the form of electromagnetic waves. This energy is absorbed by the cooler surroundings, causing the hot water to lose heat and cool down.
3. Is radiation the only way hot water can cool down?
No, radiation is not the only way hot water can cool down. Hot water can also cool down through conduction and convection. Conduction is the transfer of heat through direct contact, while convection is the transfer of heat through the movement of fluids.
4. Does the rate of radiation affect how quickly hot water cools down?
Yes, the rate of radiation does affect how quickly hot water cools down. The rate of radiation is dependent on the temperature difference between the hot water and its surroundings. The greater the temperature difference, the faster the hot water will cool down through radiation.
5. Can hot water cool down through radiation in a vacuum?
Yes, hot water can cool down through radiation in a vacuum. In fact, radiation is the only form of heat transfer that can occur in a vacuum, as there are no particles present for conduction or convection to take place. This is why objects in space, such as planets, cool down through radiation.
  • Thermodynamics
  • Mechanical Engineering
  • Thermodynamics
