Can hydrogen be abstracted from urea?
  • Thread starter Vickyl Simpl
  • Tags
    Hydrogen
In summary, urea can react with an acid to form a salt and the carbonyl oxygen of urea is protonated in the process to form uronium ion. However, there is no conclusive evidence of urea reacting with an alkali. If urea is dissolved in NaOH, it is uncertain what reactions may occur, including the possibility of hydrogen abstraction from one or both NH2 groups. To reverse the hydrolysis of cyanamide and form urea, a strong base such as metallic sodium or non-nucleophilic lithium bases like LDA or LHMDS may be used. The pKa of urea in DMSO is 26.9, making it a suitable base for this reaction.
Vickyl Simpl
Urea is known to react with an acid to form salt. The carbonyl oxygen of urea is protonated in the process to form uronium ion. But, I have not seen conclusive reaction of urea with an alkali. So, if urea is dissolved in NaOH, what are the possible reactions? Can hydrogen be abstracted from one or both NH2 group? What reagent can afford this abstraction if any.
(NH2)2CO + HCl --> (NH2)2COH+ Cl-
(NH2)2CO + NaOH --> ?
(NH2)2CO + ? --> HNCONH2 ]-
(NH2)2CO + ? --> HNCONH ]2-
The reverse reaction, namely the hydrolysis of cyanamide is used in the preparation of urea. To reverse it, you will need a rather strong base. E.g. heating urea with metallic sodium.
You need to find pKa for these protons and then find a base strong enough. Definitely won't happen in water, and I doubt it will be possible to isolate such cations as salts, but organic chemists routinely use bases that should do the trick.
Edit: DrDu beat me.
FAQ: Can hydrogen be abstracted from urea?
Can hydrogen be extracted from urea?
Yes, hydrogen can be extracted from urea through a process called steam reforming. In this process, urea is heated in the presence of steam to produce hydrogen gas.
Why is urea a potential source of hydrogen?
Urea contains a high amount of nitrogen, which can be converted into ammonia and then further processed to produce hydrogen gas.
What are the advantages of using urea as a source of hydrogen?
Using urea as a source of hydrogen is advantageous because it is a readily available and inexpensive compound. It also has a high hydrogen content, making it a more efficient source of hydrogen compared to other compounds.
Are there any challenges in extracting hydrogen from urea?
One challenge in extracting hydrogen from urea is the high energy input required for the steam reforming process. Additionally, the process also produces carbon dioxide as a byproduct, which contributes to greenhouse gas emissions.
Can the hydrogen extracted from urea be used for fuel?
Yes, the hydrogen extracted from urea can be used as a fuel source. It can be used in fuel cells to power vehicles and other applications, providing a clean and renewable source of energy.
